Homemade Vtec Killer cams
Old Dec 17, 2003 | 07:07 AM
jasonp's Avatar
Default Homemade Vtec Killer cams
I would like some info. on how to lock up vtec all the time on a bseries head without using oil pressure.. this is a full drag car and I would like some opinions to do this (pro's or con's).. thanks.. jason
Old Dec 17, 2003 | 07:14 AM
DaveF's Avatar
Default Re: Homemade Vtec Killer cams (jasonp)
couldnt ya use a relay to make the vtec stay on?
only downside i see to that would be loosing oil pressure at idle. or low rpms
Old Dec 17, 2003 | 07:49 AM
earl's Avatar
You should really ask this question in FI or AllMotor. You will get more help there.
BTW, it is done by changing the shafts that slide inside the rockers. No chance of failing that way
Old Dec 17, 2003 | 09:29 AM
Hbgsr's Avatar
Default Re: Homemade Vtec Killer cams (earl)
Make a pin that fits in all three rockers. Use steel.
Old Dec 17, 2003 | 10:07 AM
Jared's Avatar
Default Re: Homemade Vtec Killer cams (Hbgsr)
or lose some of the rotating mass by eliminating the center lobe and vtec rocker all together. just run big primary lobes.
Old Dec 17, 2003 | 11:25 AM
RS Machines's Avatar
A simple way to lock out the v-tec is to put 3 washers the size of the rockers into the holes where the pins go. You will still need to run the pins. Its hard to explain on the computer ........Any other info Please call us at 310-328-5514 ask for Jon
Old Dec 17, 2003 | 02:36 PM
Adam F's Avatar
Default Re: Homemade Vtec Killer cams (RS Machines)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS Machines &raquo;</TD></TR><TR><TD CLASS="quote">A simple way to lock out the v-tec is to put 3 washers the size of the rockers into the holes where the pins go. You will still need to run the pins. Its hard to explain on the computer ........Any other info Please call us at 310-328-5514 ask for Jon</TD></TR></TABLE>
After you put the washer in just switch the pins around so they all lock. However I would suggest against this, because it really makes it hard to set the valve lash and I think that it is not worth it unless you have cams with no primary lobes. We ran this way for about a year and the only thing I saw was increased wear on the valvetrain. If you can get custom cams then you can have someone make your primary lobes the lift that you want and remove the secondary lobe and the middle rocker. That way you can still adjust your lash properly but you have a lobe on each valve.
Old Dec 17, 2003 | 03:26 PM
Default Re: Homemade Vtec Killer cams (Adam F)
This process is done with our v-tec eliminator cams that use the center lobe only.So there is no wear on the componets. Your problem may have occured if you just locked out the v-tec and didnt have custom cams.We have been doing this process for a few years now. 10 sec all motor proven
Old Dec 17, 2003 | 03:37 PM
dfoxengr's Avatar
i havent researched it much, so im kinda ignorant to it, but why are vtec disengaging cams all that wonderful? ynot just run those huge lifts with other vtec lobes, would that not benefit more, what are the physics behind the idea of these?
Old Dec 17, 2003 | 03:59 PM
Skinner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS Machines &raquo;</TD></TR><TR><TD CLASS="quote">This process is done with our v-tec eliminator cams that use the center lobe only.So there is no wear on the componets. </TD></TR></TABLE>This is the WORST way to eliminate vtec (and wear) because it puts the load of 2 valve springs on to one lobe only. The proper way would be to use a set-up like Crane with one lobe per valve and no center lobe.
Old Dec 17, 2003 | 04:56 PM
2FastxEg's Avatar
ToMATO , tomaato..... regardless of what you guys think, i personally have used and seen the RS MACHINES KIller cams, they work really good. A guy named Eddie ran a 10.XX with them, and his set up was pretty simple too... I had them on my car, mildly built, and i ran 11.77 untuned in a EG SI hatch... John from RS would kow the most about these cams becuase ive dropped by their shop a few times and they have been doind research on it for awhile now, i think they got it pretty dialed in....... Alex-OverRev Mag..AKA.... JT Motorsports
Old Dec 17, 2003 | 06:52 PM
Big_Mike's Avatar
Default Re: (2FastxEg)
we used Crower 63413 cams with the VTEC locked and found significant wear on the rockers and the cams...not to say it doesn't work, because it did, just stating that there is evidence of wear when locking.
Old Dec 17, 2003 | 09:49 PM
turtle-eg's Avatar
Can you just use an LS head with a port job and big *** cams on it? Wouldn't this work, because basically you're just eliminating the VTEC switchover.
Old Dec 18, 2003 | 03:48 AM
ITRswapandslow's Avatar
port design and limitation on valve size with teh LS head
Old Dec 18, 2003 | 07:58 AM
DaveF's Avatar
Default Re: (RLZengineEJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RLZengineEJ6 &raquo;</TD></TR><TR><TD CLASS="quote">port design and limitation on valve size with teh LS head</TD></TR></TABLE>
and rocker arms flying off @ high rpms
Old Dec 18, 2003 | 09:30 AM
haha, that too
b20c
Jan 16, 2009 09:17 AM
dustin_crxsi
Jan 27, 2007 02:41 AM
7mile
38
Feb 15, 2006 06:59 PM
Nsane1
Jun 12, 2004 04:47 PM
itr501
Jun 25, 2001 10:06 PM
