Has anyone swapped their auto accord to manual? Added a prelude swap?
Old Dec 17, 2003 | 05:02 AM
chrisir19's Avatar
Default Has anyone swapped their auto accord to manual? Added a prelude swap?
SInce there doesn't seem to be a website like http://www.hybrid.honda-perf.org we need top start one. We are about to swap a 97 accord from auto to manual, then add our build h23a/vtec....a webiste with all the info would be great! The hyrbid guys have the link on their page but of course it's not active!!!!
If you have any info/have performed this in the past im me or hit me on aim:chrisir22
Old Dec 17, 2003 | 05:04 AM
iakona's Avatar
yes, and i inserted an H22 at the same time.
Old Dec 17, 2003 | 05:24 AM
KGAccord's Avatar
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">yes, and i inserted an H22 at the same time.</TD></TR></TABLE>
me too, but i paid a shop to do it. i still researched it before i did it though so i made sure i didn't get f'd over and did everything right.
check out the accord hybrid forum at board.hondasociety.com
Old Dec 17, 2003 | 09:03 AM
apok408's Avatar
Default Re: Has anyone swapped their auto accord to manual? Added a prelude swap? (chrisir19)
I had a 96 accord DX(auto)....now with a 95 JDM H22 (manual) motor. I did all myself, including wiring. I recommend....if you have never messed with a motorswap...do not attemp on your own. especially wiring your car from OBD2 to OBD1. Wiring the distributor/CPK was hell. I pretty much made a new harness from scratch. but you cat cut lengthen and shorten with out unravelling the harness. I just wanted it to look clean.
Old Dec 17, 2003 | 06:03 PM
chrisir19's Avatar
Default Re: Has anyone swapped their auto accord to manual? Added a prelude swap? (apok408)
yeah you got any info on the wiring the ckp and the dist..thi smakes my l5th swap or so, so i thing i casn handle this one....I even made my own homemade obd1 to obd2b jumper so i may have enough under my belt:
today we got the pedals in for the 5 speed...i need to know if we have to hard wire the clutch swithc signal wires tot he ecu, etc so the car will start...
switched water pumps for the one with the crank flux....SEt timming ( io hate balancing shafts!!!
extended a few wires...any info would be help full in the swap engine or tranny...
Thanks
Old Dec 18, 2003 | 03:28 AM
KGAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisir19 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks</TD></TR></TABLE>
if your talking about the switch that doesn't allow you to start the car with the clutch depressed, don't worry about it, i don't have it either and neither does anyone else.
the hardest part will be mounting the clutch pedal bracket, either weld it like stock to the firewall or mount it with bolts from the otherside.
Old Dec 18, 2003 | 01:31 PM
chrisir19's Avatar
Default Re: Has anyone swapped their auto accord to manual? Added a prelude swap? (KGAccord)
Well I still need to know how to wire, why you didn't even use it or how you start your car without it....
I also need some info on how to wire the car for an external coil since the lude swap needs and internal one..?? please advise!
Old Dec 18, 2003 | 07:01 PM
chrisir19's Avatar
TTT
Old Dec 19, 2003 | 09:24 AM
chrisir19's Avatar
bump...we only have like 5 things standing in out way...? how do we wire this damn coil from internla to external...!
Old Dec 21, 2003 | 10:12 AM
chrisir19's Avatar
bump still need some help...? how to wire the extenral coil when the harness is for an internal one....
Old Dec 21, 2003 | 10:36 AM
KTeller8's Avatar
some more help from your brownnoser buddy
dissy help
http://accordinglydone.com/tech.php?ID=57
auto to stick..
http://accordinglydone.com/tech.php?ID=31
Old Dec 22, 2003 | 03:01 PM
chrisir19's Avatar
Default Re: Has anyone swapped their auto accord to manual? Added a prelude swap? (KTeller8)
chrisir19 (4:15 AM 12/22/2003): I have to formally apologize and very gladly thank you for helping us!!!!
KTeller8 (4:12 PM 12/22/2003): hey man, no problem:
like i said, tons of info out there, when i did my swap , it didnt go right and i was freaking out, i understand.. Good luck buddy,
you might also want to keep track of how things up and can always edit and update those links
Old Dec 22, 2003 | 09:27 PM
KTeller8's Avatar
yep good stuff.. hope it helps.
let me know,, email me if you cant post anymore!
chevyboy712
Apr 7, 2015 08:52 PM
anthy08
Jan 25, 2015 08:02 PM
96blackhatch
May 31, 2005 03:08 PM
eg686
Oct 26, 2003 08:40 PM
