how much does a b16 head usually go for
Old Dec 16, 2003 | 11:51 PM
thehammer
Guest
Posts: n/a
Default how much does a b16 head usually go for
what should I expect
Old Dec 17, 2003 | 12:07 AM
vivid02's Avatar
Default Re: how much does a b16 head usually go for (thehammer)
1st gen 450 2nd gen 550
Old Dec 17, 2003 | 12:48 AM
thehammer
Guest
Posts: n/a
Default Re: how much does a b16 head usually go for (vivid02)
which one is better for a 1996 integra ls, I take it second gen
Old Dec 17, 2003 | 01:30 AM
1998_4dr_gsr's Avatar
2nd gen= higher compression= more hp
Old Dec 17, 2003 | 05:05 AM
quikB18B's Avatar
Default Re: (1998_4dr_gsr)
Complete B16a2 head with manifold no distributor
$500-$550 depending on miles
Old Dec 17, 2003 | 07:28 AM
hondahans's Avatar
Heads are the same cast, higher compression from 2nd gen pistons. get what is cheapest. Don't be affraid to travel a litlle, I got my Gsr head complete with everything , dist. IM, TB, nology wires, complete engine harness and a clean valve cover to boot!. - for 600 and all I had to do was drive 45 mins. into Jersey....Honda-Tech rules!
Old Dec 17, 2003 | 11:52 AM
Rob Dizzle's Avatar
Default Re: (hondahans)
if you look around it can be below 500 for a complete setup
i got my gsr head which was complete from dan phan at rcrewracing.com for under 600
call around to importers to see if they have any b16 heads, or a get a complete swap for cheap and sell off the bottom end
Old Dec 17, 2003 | 12:31 PM
IntegrasGoFast's Avatar
go to your local shop....they told me $500 for the whole setup...new ecu and everything....worth it to ask anyway
Old Dec 17, 2003 | 12:37 PM
slowturtle's Avatar
Default Re: (Bob-DC2)
dan phan rcrewracing.com very good thats where i'm getting my head also
Old Dec 17, 2003 | 02:58 PM
turboxsi's Avatar
Default Re: (slowturtle)
try http://www.noyanusa.com
Old Dec 17, 2003 | 03:43 PM
riceball777's Avatar
without distrubiton $400-500
pwesonally i have seen them go for 400 many time and i would not pay more that 400 or 450
Old Dec 18, 2003 | 10:47 AM
thehammer
Guest
Posts: n/a
Default Re: how much does a b16 head usually go for (riceball777)
really what is there to look for when purchasing one
Old Dec 18, 2003 | 01:31 PM
vtecb20coupe's Avatar
B A N N E D
anywhere from 450-600, depending on what it comes with . i've sold 1st gen heads with no dizzy or manifold/throttle bodies for $475-500. just depends on demand and what part of the country you're in.
numberone
Jan 5, 2009 07:14 PM
showtymers619
Aug 28, 2004 02:02 AM
1slowcrx
Jun 3, 2004 02:49 PM
showtymers619
May 11, 2004 06:10 AM
onetwothree
Mar 17, 2003 08:49 AM
