gsr takes long crank to start randomly
mine only does it when i am low on gas. try turning the key on to accesory for like 5 seconds before you start it. mine starts fine whenever i do this even when low on gas.
Whens the last time you had a tune-up? Keep your plugs, wires, cap and rotor. If there's lots of corrosion near your battery terminals, clean it with sprite soda
. Trending Topics
Ok, my personal experience.
My car wouldnt crank right off. Battery was going out and after I replaced it, it cranked just fine...with the colder weather your battery is getting pushed hardier, so it might be time to pick up a new one...better to do it now then when your at the store and you cant get your car cranked. Also, after grounding wires the car cranks much faster.
B_Swapped93
Apr 22, 2013 10:12 AM
Audio28
Jul 3, 2003 05:33 PM
