can anyone convert kg per mm into lbs?
Old Sep 21, 2001 | 12:21 PM
91ED7Si's Avatar
Default can anyone convert kg per mm into lbs?
whats 450 and 350 in lbs?
Old Sep 21, 2001 | 12:29 PM
rickshank's Avatar
New User
Default Re: can anyone convert kg per mm into lbs? (91ED7Si)
hmm...
if you're doing KG per MM to LBs per IN , it's
(x) KG/MM * (2.2/25.4) = y LBs/IN
stick in x, times it by 2.2, divide by 25.4, and you get lbs/in ... if u want to go the other way, take your lbs/in , multiply by 25.4, then divide by 2.2 , and you have kg/mm
~Rick Shank
Former Computer Engineer major
Old Sep 21, 2001 | 12:33 PM
91ED7Si's Avatar
Default Re: can anyone convert kg per mm into lbs? (rickshank)
thanks..
i got a new set of springs and theyhave 450 written on two of them and 350 on the other..
i supose this is the spring rate in kg mm..
but when i did the converson i got 38.95??
that seems really high??
Old Sep 21, 2001 | 12:41 PM
MysteryWagon's Avatar
so did they turn out to be in good shape?
Old Sep 21, 2001 | 12:43 PM
rickshank's Avatar
New User
thanks..
Nope! Those are lb/in rates on springs. I run 550 lb/in up front, 500 lb/in in the rear of my 89 civic si , it's a CSP autocross car. 450/350 would be a nice stiff but still street worthy combo. I only run 400 lb/in springs in the rear of my 1600 lb crx
Old Sep 21, 2001 | 03:26 PM
91ED7Si's Avatar
Default Re: can anyone convert kg per mm into lbs? (ShaggenWaggon)
yep..it turns out he didnt buy them used..he bought them off ebay and he never installed them so they have 0 miles.
4 coilovers for 50$ never used aint bad huh
Old Sep 21, 2001 | 03:29 PM
91ED7Si's Avatar
btw thanks for the info rick.
greatly apreciated
Old Sep 21, 2001 | 04:00 PM
well, thats pretty cool, If I where you I would still wait to get shocks before putting them on your car.
good dill, you should look up more info on the type of coilovers they are. Learn a little but more about them.
talk to you later
Old Sep 21, 2001 | 04:07 PM
91ED7Si's Avatar
i did a google search and looked on the site they came for..nothing.
he said they were rsr..
only thing they say on them is cbw and the spring rate stickers.
i didnt even get a window sticker man..how am i suposted to let people know im cooool.
7rrivera7
Suspension & Brakes
Feb 9, 2012 06:29 AM
jbuck2kcivic
Suspension & Brakes
11
Aug 19, 2009 10:24 PM
donut.
Suspension & Brakes
10
Feb 25, 2008 06:01 PM
akkord94
Dec 29, 2003 02:48 PM
rockwilda
Aug 8, 2001 09:35 AM
