JDM rear upper arms
Old Sep 21, 2001 | 11:01 AM
albert butterbikini's Avatar
New User
Default JDM rear upper arms
Will i need an alignment after installing these? Anyone here have them?
Old Sep 21, 2001 | 11:19 AM
HapaHaole's Avatar
Default Re: JDM rear upper arms (typeR158)
no allignment necessary if they are not adjustable. are they even different than usdm??? if anything they are shorter, but i highly doubt it. better to get some adjustable upper links.
Old Sep 21, 2001 | 11:29 AM
Todd00's Avatar
I said I don't want a title!
From what I can tell, they give you more rear camber. Isn't rear camber the last thing you want for the track or autox in a FWD car? When you lower your car you'll get it anyway.
Perhaps they use these on the JDM cars because the JDM ITRs have a larger rear sway. I dunno.
Old Sep 21, 2001 | 11:38 AM
Chris's Avatar
Default Re: JDM rear upper arms (Todd00)
Hmmmm...I did not know that...Are you sure?
Old Sep 21, 2001 | 11:39 AM
Dropspeed's Avatar
Why would you not want camber in the rear?
The USDM part is a stamped part and the JDM is made differently with a solid tube. I don't know why they are different. anyone?
Old Sep 21, 2001 | 11:59 AM
H-PIMP's Avatar
Default Re: JDM rear upper arms (Dropspeed)
JDM ITR's have a tighter, more defined rear suspension. Rear upper strut bar, rear upper tubular control arms, and, 23mm rear sway bar (as opposed to 22mm in USDM). These improvements mated with 16x7 wheels and 215/45 rubber make the JDM ITR a better handler and stopper.
Old Sep 21, 2001 | 02:06 PM
Todd00's Avatar
Default Re: JDM rear upper arms (H-PIMP)
JDM rear upper arms are a bit shorter than the USDM arms. And yeah, the JDM is not stamped pieces like the USDM.
Shorter upper arms will give you more camber in the rear. Then again, Jap spec cars always seem to set their cars up not to oversteer, which more camber in the rear would help with.
Old Sep 21, 2001 | 02:18 PM
Gansan's Avatar
I agree with H-PIMP. The JDM upper control arm was a running change made for the 98 model year to provide better camber rigidity. When I installed King Motorsports' camber adjuster on my rear suspension (which uses spherical bearings), the increased rigidity was immediately noticable and very welcome. Mr. Ichishima of Spoon also recommends getting the 98 spec part according to an interview with him in a BM video.
swizz977
10
Dec 23, 2011 09:07 PM
Willard
Jun 8, 2005 01:48 PM
00 FBP ItR
Jan 27, 2004 12:45 PM
REVolution
Dec 7, 2001 06:57 AM
jet
Oct 3, 2001 08:22 PM
