b18c swap in ek
Old Dec 16, 2003 | 04:44 PM
ci9v7ic's Avatar
Default b18c swap in ek
just did a swap on a 97 ex. went from auto d-series to b18c 5-spd
check it out.
Old Dec 16, 2003 | 05:34 PM
tueyjk's Avatar
ci9v7ic,
I'm about to do a d-series auto swap to a B16A2 5-spd. Did you have to cut any holes in the floor board? Patch any holes in the floorboard? I've read a lot of articles of people having to cut out the automatic shift cable bracket, etc.
BTW, looks good.
Jim
Old Dec 16, 2003 | 05:48 PM
aw1234dude's Avatar
Default Re: (tueyjk)
Nice, more pics more pics
Old Dec 16, 2003 | 07:10 PM
Maintenance's Avatar
Default Re: (Manuel)
sweet. How long did the whole swap and auto to manual conversion take you?
Old Dec 16, 2003 | 09:12 PM
IS3Fifty's Avatar
Default Re: (racerxfear)
Nice, looks good from at least that pic. How'd the auto to manny go?? I have a 98 EX auto that I was planning on swapping to manual, but really didnt want to go through the hassle of tranny changeover.
Old Dec 16, 2003 | 10:13 PM
SPOON DC2's Avatar
Default Re: b18c swap in ek (ci9v7ic)
very nice!
Old Dec 17, 2003 | 11:20 AM
99EKhatch's Avatar
Default Re: b18c swap in ek (SPOON DC2)
how you like the power diff?
Old Dec 17, 2003 | 05:30 PM
ci9v7ic's Avatar
the whole swap took about 9 hrs. the only problem converting auto to manual was the housing where the auto shift cable went through the floor. i had to remove and patch it because the shift linkage hit it. also had to connect the two large wires on the shifter so the car would start. then the key wouldnt come out so i removed the mechanism in the steering column that retains the key when not in park. overall it was very easy. if you do this swap, i recomend an ex engine harness, and obd-2 jdm computer because the jdm computers dont require a crankshaft position sensor and its plug and play, no obd2 to 1 jumper harness. the car is completely different. the v-tech hits very hard . the car rips nasty. very nice upgrade!
Old Dec 17, 2003 | 05:36 PM
slammed_93_hatch's Avatar
its vtec dude. not vtech, thats a type of portible phone
Old Dec 17, 2003 | 06:21 PM
VTECVillain's Avatar
Good to see you got everything together that quickly. You did wire up your reverse lights didn't you? I never saw that mentioned so I thought I would ask.
Old Dec 17, 2003 | 07:37 PM
ci9v7ic's Avatar
Default Re: b18c swap in ek (VTECVillain)
i havnt checked the reverse lights. thanks
Old Dec 17, 2003 | 07:40 PM
ci9v7ic's Avatar
misspelled it : [B]v-tec [B] is that better?
Old Dec 18, 2003 | 09:50 AM
Denis Si's Avatar
I see you kept your AC and PS right?
Did yo modify the brackets by any chance, with the compressor (D) fit b engine?
i got 99 ex 5spd, and got an itr engine, and i dont really care about PS, but i gots to keep the AC
give me some detaisl on that man, thanx
Old Dec 18, 2003 | 11:48 AM
antzemail's Avatar
Default Re: (aw1234dude)
I have a HX alot of people say I should swap in a 98 EX Wiring harness would you guys recomend that over the HX's
Old Dec 18, 2003 | 12:09 PM
tueyjk's Avatar
antzemail,
I have an HX as well, 1999 to be exact and I will be using a '99 SI wire harness for my swap.
My swap is a '99 B16A2.
I haven't heard of anything in regards to using an EX harness. What have you heard?
Jim
Old Dec 18, 2003 | 12:11 PM
tueyjk's Avatar
ci9v7ic,
Thanks for the response.
I'll crawl under my car to see if I need to cut out the shift cable housing. I'm hoping that I won't have to, but it sounds like I might.
Would it be possible for you to take pics of the shifter with the center console and shift boot removed?
Jim
Old Dec 18, 2003 | 03:52 PM
ci9v7ic's Avatar
Default Re: b18c swap in ek (Denis Si)
get a del sol a/c bracket. b-series
Old Dec 18, 2003 | 03:54 PM
ci9v7ic's Avatar
Default Re: (antzemail)
definately get the ex harness. it will save you alot of hassle
Old Dec 18, 2003 | 03:57 PM
ci9v7ic's Avatar
Default Re: b18c swap in ek (tueyjk)
it all looks the same as the five speed from the top but underneath is where the modifying takes place. you also have to drill holes for the shift linkage to bolt in.
Old Dec 18, 2003 | 04:40 PM
Denis Si's Avatar
ok so i need del sol AC bracket and thats it? excellent?
Old Dec 18, 2003 | 08:00 PM
Hybrid2Be's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel &raquo;</TD></TR><TR><TD CLASS="quote">Nice Low 14sec Car</TD></TR></TABLE>
i love to see that.. lmao
nice swap btw
Old Dec 18, 2003 | 11:12 PM
GOLDBERG's Avatar
what powersteering bracket and pump did u use?
Old Dec 18, 2003 | 11:29 PM
SleepnCiViC's Avatar
uhh you wont see low 14's w/a b18c or b16a swap into a EK in stock form.... ive got a bic18c5 in my EK and ran a 14.6.
Old Dec 19, 2003 | 01:06 AM
ci9v7ic's Avatar
Default Re: b18c swap in ek (GOLDBERG)
i used the gsr bracket, d-series pump with a smaller belt
Old Dec 19, 2003 | 08:30 PM
Dammit_Dan_954's Avatar
yes the del sol dohc vtec a/c bracket lets u bolt a single cam a/c compressor to it. if u know what your doing or the shop they should be able to do the swap without even discharging the ac. I think the bracket is around $130 from honda.
