is this fixeable????
Old Dec 16, 2003 | 03:43 PM
HaTcH_BmX's Avatar
Default is this fixeable????
would i be able to fix this head up??? well not me, the machine shop
edit: sorry for the huge pics, but idont know how to resize them
Modified by HaTcH_BmX_Ep3 kid at 1:01 AM 12/17/2003
Old Dec 16, 2003 | 04:01 PM
HaTcH_BmX's Avatar
Default Re: is this fixeable???? (HaTcH_BmX_Ep3 kid)
help !!!!!!!!!!
Old Dec 16, 2003 | 04:38 PM
-16V-'s Avatar
It looks fixable, but with cost some $$$$$.
new valve guides,valves and valve seals.
Old Dec 16, 2003 | 07:40 PM
This One's Avatar
Default Re: is this fixeable???? (1991_jdm_sleeper)
throw that **** away
Old Dec 16, 2003 | 08:11 PM
doublejz's Avatar
Default Re: is this fixeable???? (tHIS oNE)
damn that looks like ***, just go pick up another head, would probably be cheaper. a shop would probably be able to fix it but it most likely not gonna be worth it. what you do snap a timing belt?
Old Dec 16, 2003 | 09:01 PM
HaTcH_BmX's Avatar
Default Re: is this fixeable???? (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">damn that looks like ***, just go pick up another head, would probably be cheaper. a shop would probably be able to fix it but it most likely not gonna be worth it. what you do snap a timing belt?</TD></TR></TABLE>
nop actually im about to buy it as an extra head to work on it, i found it for really cheap considering that is a 2002 head, came of from a rsx type s, i already have a type s head ( not on my car) but i have it, i just want to know of this is fixeable, if it will cost me 300-400 to fix, it is still a pretty good deal for the price i had it.
Old Dec 16, 2003 | 09:10 PM
IS3Fifty's Avatar
going to have to agree with this guy..... Yes, its fixable, but when not really knowing what it will cost you, you might as well just buy a new head. On the other hand, if you were planning some MAJOR head work, then you'd be redoing the whole thing anyways. What exactly did you/the person that had that head do?
Old Dec 16, 2003 | 09:14 PM
HaTcH_BmX's Avatar
Default Re: is this fixeable???? (TODAeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">
going to have to agree with this guy..... Yes, its fixable, but when not really knowing what it will cost you, you might as well just buy a new head. On the other hand, if you were planning some MAJOR head work, then you'd be redoing the whole thing anyways. What exactly did you/the person that had that head do?</TD></TR></TABLE>
overrev it, exactly, if im gonna do head work on it is worth, right?? i just had it so so cheap, adn that's why im interested on it, i might send it to a local shop, if not toimport builders or somewhere else to rebuild the whole thing, the only thing i was wondering was if it was fixeable. thanks guys
Old Dec 16, 2003 | 09:21 PM
dategb16vortech's Avatar
you must have revved the living **** out of it! how high did you take it and did a vavle snap or hit the piston. more specifics please.
Old Dec 16, 2003 | 09:23 PM
HaTcH_BmX's Avatar
Default Re: is this fixeable???? (dategb16vortech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dategb16vortech &raquo;</TD></TR><TR><TD CLASS="quote">you must have revved the living **** out of it! how high did you take it and did a vavle snap or hit the piston. more specifics please.</TD></TR></TABLE>
dude, i didnt do it, im gonna buy the head as it is, the person who owned the car overrev'd it and took it to the dealer, the changed the whole engine and now a guy is selling me the head
Old Dec 16, 2003 | 09:24 PM
IS3Fifty's Avatar
Im not extremely schooled on burned up heads, but for the most part block/heads alone are strong, internals are were your problems really lie. If you are planning on FULLY REWORKING the head, then hell if it's not cracked (visibly) then use it. If you take it to import builders, they will definately be able to give you the heads up, but more than likely you can rebuild. Who wants to pay 500+(or whatever they cost) for a k20 head, when all your going to do it gut the whole thing?
Old Dec 16, 2003 | 09:31 PM
HaTcH_BmX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">Im not extremely schooled on burned up heads, but for the most part block/heads alone are strong, internals are were your problems really lie. If you are planning on FULLY REWORKING the head, then hell if it's not cracked (visibly) then use it. If you take it to import builders, they will definately be able to give you the heads up, but more than likely you can rebuild. Who wants to pay 500+(or whatever they cost) for a k20 head, when all your going to do it gut the whole thing?</TD></TR></TABLE>
put it this way, those heads run for 700+ or even much more, depends on where you buy it if you find one, even if i have to pay 500 to rebuild it, i still have a pretty good deal. but like i said, the problem is only on chamber # 4, so i dont think it would be THAT MUCH to fix it, probably the port and polished of it will cost more than fixing the guides, right?
Old Dec 16, 2003 | 09:37 PM
IS3Fifty's Avatar
yeah, I think a port and polish usually runs about 500. Check out aguilar racing, he has some stuff about where he gets his motor work done. I dont know the address off the top of my head, but Im sure you can find it pretty easy.
Are you retaining stock internals? Meaning your not going with aftermarket valves, retainers, rings, etc.
Old Dec 16, 2003 | 09:44 PM
HaTcH_BmX's Avatar
type r valve train, i should hit 210 whp+ easily with this head, prc pistons and some other goodies, like 1500 dollars to get there, not bad, huh??
Old Dec 16, 2003 | 09:47 PM
IS3Fifty's Avatar
not bad did you buy all the OEM stuff from honda?? or used from a type r head?
Old Dec 16, 2003 | 09:52 PM
HaTcH_BmX's Avatar
i'll buy the valve train next month but i already talked to the guy and semms like im getting it for 400, and to answer the question, no, i bought most of the part from "kids"
Old Dec 17, 2003 | 06:08 AM
IS3Fifty's Avatar
why dont you give Marcus a call at HeeltoeAuto.com tell him Chris from PA sent you. He sells OEM parts all the time, great prices, and he's awesome to work with.
Old Dec 17, 2003 | 04:29 PM
HaTcH_BmX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">why dont you give Marcus a call at HeeltoeAuto.com tell him Chris from PA sent you. He sells OEM parts all the time, great prices, and he's awesome to work with. </TD></TR></TABLE>
ok. this guy deals with all honda/acura parts from japan??, because im looking for a type r valvetrain
Old Dec 17, 2003 | 09:27 PM
IS3Fifty's Avatar
yes most of his parts are from Japan. He was one of the only people to carry the Genuine Honda CTR alt. pulley. He'll help you out.
Old Dec 18, 2003 | 08:46 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HaTcH_BmX_Ep3 kid &raquo;</TD></TR><TR><TD CLASS="quote">
nop actually im about to buy it as an extra head to work on it, i found it for really cheap considering that is a 2002 head, came of from a rsx type s, i already have a type s head ( not on my car) but i have it, i just want to know of this is fixeable, if it will cost me 300-400 to fix, it is still a pretty good deal for the price i had it.</TD></TR></TABLE>
what's the name of the shop, that's going to fix that head? i have a head that i might want them, to take a look at to see if it's reparable!
Old Dec 18, 2003 | 09:19 PM
IS3Fifty's Avatar
Default Re: is this fixeable???? (smokey2.0)
i think he's going to take it to ImportBuilders.com
Old Dec 19, 2003 | 09:50 AM
HaTcH_BmX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
what's the name of the shop, that's going to fix that head? i have a head that i might want them, to take a look at to see if it's reparable!</TD></TR></TABLE>
i dont remember the name of the shop, but is in the same building as cartek-tuning, and spoon motorsports, it in davie fl, st rd 84 and 70th street
Old Dec 19, 2003 | 04:51 PM
smokey2.0's Avatar
i dont remember the name of the shop, but is in the same building as cartek-tuning, and spoon motorsports, it in davie fl, st rd 84 and 70th street </TD></TR></TABLE>
that's enough info for me, i might just call cartek and ask them if they know them
Old Dec 20, 2003 | 08:01 AM
its WANG yoO's Avatar
stick a fork in it susie..................SHES DONE!!!!
Old Dec 20, 2003 | 09:41 AM
JDMH22HATCH's Avatar
Default Re: is this fixeable???? (inJDMtegra)
Its not that bad to fix. Its around $175 depending on how bad. They reweld the chamber, replace the valve seals, guides, etc, and machine the bowls and everything. The pic below is the head I have that I got the estimate on and the estimate was $175. Just have all the chambers reworked and build the head to your satisfaction.
