Goodridge stainless brake lines
Old Sep 21, 2001 | 09:27 AM
Wet Nudl's Avatar
New User
Default Goodridge stainless brake lines
Are these any good? Do all 94+ Integra (ITR, GSR, LS) share the same brake line configuration?
Old Sep 21, 2001 | 09:30 AM
Chris's Avatar
Default Re: Goodridge stainless brake lines (TypeRP)
Yes...and I think so.
I have the Goodridge lines. I suggest though that if you get them, check them frequently. Unless you are on the track alot, they wont help much. I personally consider them a safety item, more than a performance upgrade.
Old Sep 21, 2001 | 09:37 AM
B18CXr's Avatar
Money well spent
ALL DC2's will use the same lines.
Old Sep 21, 2001 | 09:56 AM
Wet Nudl's Avatar
New User
Default Re: Goodridge stainless brake lines (Chris)
Why should I check them freqently? I don't expect any performance gain from the SS lines, just higher temp rating than rubber lines and less chance of cracking. Also, how much do they run new?
[Modified by TypeRP, 10:57 AM 9/21/2001]
Old Sep 21, 2001 | 10:05 AM
Chris's Avatar
I hear that they are not as resilient as rubber. The Goodridge lines *could* get debris trapped in between the steel braids and cause failure. The benefit to rubber is you can SEE the cracks and bubbles.
This is only what I have read...although I took it with a grain of salt and use them myself. I just want to be safe and check them every so often.
I also read when I was researching them that the crimp on ends are prone to un-crimping....just take it FWIW
fastbrakes's Avatar
With any braided line, you need to make sure they are not rubbing anything or they will wear thru and break. Unless they have the plastic sleeve on them it's best to check them every once in a while...
Old Sep 21, 2001 | 10:08 AM
Chris's Avatar
Good point about the temp resistance... I think they are anout $100 for a set.
Foster Zygote
12
Feb 19, 2010 10:18 AM
JDM.Type-r
Jan 24, 2008 01:35 PM
BAYsikDC4
Apr 20, 2007 11:29 AM
Blazineyez
Apr 6, 2006 10:25 AM
HondaGSR
Honda Motorcycles
Feb 3, 2003 04:09 PM
