H23A Vtec (from 99 Accord SiR-T) NOT hybrid..
Old Dec 16, 2003 | 11:41 AM
yohan's Avatar
Default H23A Vtec (from 99 Accord SiR-T) NOT hybrid..
I'm thinking about getting this engine and pairing it up with either H22 LSD transmission or my stock H23 one for a swap in the future... then putting a P13 ECU to it ...
Does anybody know the CR of the pistons in this engine ?? Also, the H23A is ODB2, if im putting this up to an ODB1 ECU what may need to be changed?
Anybody else criticize this to an easy route to get H23 Vtec (low tq. with vtec of H22 ?? ) BESIDES all of the regular assumed downsides to it ? (ie high revving will snap the cranks, pin bearrings etc.)
Old Dec 16, 2003 | 11:48 AM
AndyD's Avatar
Default Re: H23A Vtec (from 99 Accord SiR-T) NOT hybrid.. (yohan)
You will need ODBI injectors.
Old Dec 16, 2003 | 11:59 AM
4bidden's Avatar
10.6:1
200ps@6800
95mm stroke
It comes out of one of these babies.
Old Dec 16, 2003 | 12:05 PM
yohan's Avatar
Can anybody post the quick specs on the USDM H23 ?? its like 9:1 or 9.1:1 CR but whats the stroke ?
4bidden, thats fantastic thanks! the 6800rpm .. is that horse or torque? .. (ps = )
Old Dec 16, 2003 | 12:12 PM
93accordEX's Avatar
Default Re: (yohan)
its close to hp. thats like 197 hp...
Old Dec 16, 2003 | 12:36 PM
4bidden's Avatar
Default Re: (yohan)
That is the peak HP. It doesnt rev like the H22 due to its longer stroke.
PS is short for Pferdestärke. 200ps = 197.26HP
Old Dec 16, 2003 | 01:03 PM
yohan's Avatar
I really think I want to go this route...
Swapping from H23 I need to :
Swap in ODB1 fuel injectors
JDM ODB1 P13 ECU
New Clutch
H22 w/ LSD or my existing H23 Tranny.
Wire up the Vtec ...
Old Dec 16, 2003 | 01:04 PM
4bidden's Avatar
Default Re: (yohan)
I dont think the engine is worth it, but do as you wish.
What are you paying for it?
Old Dec 16, 2003 | 01:08 PM
PirateMcFred's Avatar
Default Re: (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">PS is short for Pferdestärke. 200ps = 197.26HP</TD></TR></TABLE>
Pferdestärke is literally "horsepower." It's german. Probably just a little different temp/pressure standards than SAE, but still a bastardization of english and metric.
the Pirate
Old Dec 16, 2003 | 06:02 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">I dont think the engine is worth it, but do as you wish.
Me either.
Also, stock H23 compression is 9.8:1
Old Dec 16, 2003 | 06:25 PM
H23vtecEG's Avatar
[QUOTE=4bidden]I dont think the engine is worth it QUOTE]
exactly. he might not like the idea, but if you do go for it
Old Dec 16, 2003 | 07:02 PM
yohan's Avatar
Well ... Its factory built, the same as the hybrid, only no engine work has to be done, .. so for stock form, blue valve cover (wooOo) putting in new clutch, timing belt, water pump etc. onto this and adding a tranny would yield the same as if I were to hybrid ... and its not like im going to rev hard all the time either ... im plenty happy if I stopped at 7200 ..
I should still be able to spank USDM ludes stock for stock and will not loose any torque out of my present config ...
Why do you guys not like the idea of this out of curiosity?
Old Dec 16, 2003 | 07:58 PM
fastludeh22's Avatar
Default Re: (yohan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yohan &raquo;</TD></TR><TR><TD CLASS="quote">Why do you guys not like the idea of this out of curiosity?</TD></TR></TABLE>
price...just like the type-s waaaaaay overpriced. what have you been quoted.
Old Dec 16, 2003 | 08:16 PM
Zimmlude's Avatar
Since it is OBD-II you will need to get an OBD-I dizzy as well as the OBD-II ones are different. If you put OBD-I injectors and a P13 you will most certainly have to remap the fuel curves somehow as well. If you run stock H22 maps it will run rather lean and confuse the hell out of the ECU.
It is a lot of work but could be a lot of fun if done right. Gotta love the H23 torque curve.
Old Dec 17, 2003 | 07:55 AM
yohan's Avatar
So use the distrib off my ODB1 H23
I beleive the fuel injectors are the same.. if not can be found for odb1 H22.
VAFC and a bit of tuning ... and bam, off to the races.
Just have to find a longblock&head for cheapy now..
Old Dec 17, 2003 | 04:19 PM
satan_srv's Avatar
yeah the H23 VTEC is a much nicer block than the H23 of old. It's open deck and has the larger crank mains...I'd feel more comfortable revving that motor.
But i do know that the H23 VTEC has a really funky distributor on there..you should defintely swap it if you can.
USDMMARK
Jun 8, 2003 06:40 PM
KENLUDE97
Mar 7, 2003 07:35 AM
optikal_blitz
Mar 2, 2003 03:19 PM
Kp_VtekNiks
Nov 13, 2002 10:24 AM
