how can i tell the difference btwn type S and h22?
Old Dec 16, 2003 | 10:57 AM
F120man's Avatar
New User
Default how can i tell the difference btwn type S and h22?
im planning to pick up a JDM prelude type S motor, but to prevent any misidentification between the type S and the regular jdm h22a motor. what are the visual differences that i can use to make sure that im getting what im paying for? in addition, in the USDM motors, whats the difference between the type SH motor and the regular USDM h22a4 motor?
Old Dec 16, 2003 | 11:04 AM
Mikeyslude's Avatar
JDM H22A is 200, the H22A Type S is 220, the H22A Spec S is 220
USDM H22A1 is 190, 97-98 SH & Base H22A4 is 195, 99+ H22A4 is 200.
Old Dec 16, 2003 | 11:13 AM
PR_Prelude's Avatar
Default Re: how can i tell the difference btwn type S and h22? (F120man)
Most importantly, the Type S should have a Red Valve Cover and if you are picking it with a tranny it should be ATTS. If you are picking an S-Spec motor, it should also have the Red Valve Cover but should have an LSD tranny.
Between the Base USDM H22A4 and Type SH the major difference is the ATTS, and some other differences but those are because of the ATTS.
Old Dec 17, 2003 | 06:34 PM
F120man's Avatar
New User
Default Re: (Mikeyslude)
if thats hp rating, i already know that, i just needed some visual confirmation. such as the stamps on the head and block that might be different. how do i know if the tranny has atts? i know if you look at the axel hole, there shouldnt be a bar there.
Old Dec 18, 2003 | 03:11 AM
Vrag's Avatar
ATTS Tranny have 2 oil filler plug
One for MTF on the right side of car and second for ATF (signed MCU OIL) for ATTS on another side
Old Dec 18, 2003 | 06:08 AM
PirateMcFred's Avatar
Default visual Identification...
JDM type-s (the 220hp with ATTS) has "P5P" cast on the back of the block directly behind clyinder #3 just right of where the oil filter would be on a base model. the only problem is if the engine is complete, I think that the ATTS unit is directly in front of that. If the head (red valvecover) is off the 11:1 pistons are obvious with "P5P" cast into the top of them. The head is mildly ported If you can look behind the valves, or down the ports. I have pics but have no host if you are interested in what I am talking about I can email them. HTH
the Pirate
Old Dec 18, 2003 | 08:14 AM
Bs2kB6
Guest
Posts: n/a
Default Re: visual Identification... (PirateMcFred)
how much whp does the TYPE S motor have (220 hp) and is the vtec louder than the USDM type R's?
willfly
Aug 7, 2013 06:55 PM
SpeedMachine
Oct 28, 2004 01:37 PM
slowpokesi
May 28, 2004 01:17 PM
96hatch22
11
Sep 23, 2003 11:17 AM
