Honda S2000 Honda S2000
Comparing an s2000's vtec noise to a b16a2 - louder? Quieter?
Old Dec 16, 2003 | 09:51 AM
WarriorSeer's Avatar
Default Comparing an s2000's vtec noise to a b16a2 - louder? Quieter?
I am interested in buying a honda. My friend has a civic hatchback with a b16a2. When vtec kicks in it is CRAZY loud, it turns people's heads on the highway. It's like the engine goes hummmmmmmmmmmmm-BAAAAAAAAAAAAAAAAA!!!!!!!
What I would like to know, is does the vtec noise of the s2000 sound the same, louder, or quieter?
And if the vtec noise sounds quieter, would a different exhaust change that?
Lastly if any of you s2000 drivers have driven a hatch with a b16 engine, how does it compare in terms of power, low and high?
On a side note, how can I view topics older then december? When I click on 60 days or 365 days it still only goes back to december 1st. Is there an archive somewhere?
Modified by WarriorSeer at 7:23 PM 12/16/2003
Old Dec 16, 2003 | 10:36 AM
mooboygsr's Avatar
Default Re: Comparing an s2000's vtec noise to a b16a2 - louder? Quieter? (WarriorSeer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WarriorSeer &raquo;</TD></TR><TR><TD CLASS="quote">I am interested in buying a honda. My friend has a civic hatchback with a b16a2. When vtec kicks in it is CRAZY loud, it turns people's heads on the highway. It's like the engine goes hummmmmmmmmmmmm-BAAAAAAAAAAAAAAAAA!!!!!!!
Modified by WarriorSeer at 7:23 PM 12/16/2003</TD></TR></TABLE>
Is your friend's b16a2 hatch have a stock exhaust? I think that the b16a2 may either be the same or louder. You probably should just compare the two cars in real life. Take your friend's hatch down to the honda dealer and do a test drive.
Old Dec 16, 2003 | 11:01 AM
Default Re: Comparing an s2000's vtec noise to a b16a2 - louder? Quieter? (mooboygsr)
Nope not a stock exhaust. But the sound i hear is definitely coming from the engine, someone else said it may be due to his intake.
Old Dec 16, 2003 | 11:22 AM
Phaze2 Mike's Avatar
No vtec at stock vtec point is louder then the f20c, except maybe the b18c5. (I have driven hatchs/delsols with every vtec bseries)
Old Dec 16, 2003 | 11:41 AM
mooboygsr's Avatar
Default Re: (yellowfever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowfever &raquo;</TD></TR><TR><TD CLASS="quote">No vtec at stock vtec point is louder then the f20c, except maybe the b18c5. (I have driven hatchs/delsols with every vtec bseries)</TD></TR></TABLE>
Your probably right... I have a GS-R also, and it they seemed kind of similar. But now both cars have aftermarket exhausts so they are both nice and loud.
Old Dec 16, 2003 | 12:04 PM
I am glad to hear this! There are several used ones in my area hovering around low 22-25$k. I originally wanted a corvette because my brother has one. But even though the corvette and my friend's hatch are evenly matched, because of vtec, the hatch FEELS faster, and I like that rush. The corvette is just so linear and only has a punch off the line.
Old Dec 17, 2003 | 06:50 PM
TommyV's Avatar
I'm sorry but the RSX-S is SUPER LOUD! I've been to a number of autoxs where I have to remove my stock air box cover to compete with the noise the RSX-S makes in VTEC. ANd my friend's 95 hatch with a 99SI engine and stock air box, modded a little, is very loud too.
Old Dec 18, 2003 | 01:06 PM
SpoonSpecR's Avatar
Default Re: (TommyV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TommyV &raquo;</TD></TR><TR><TD CLASS="quote">
I'm sorry but the RSX-S is SUPER LOUD! </TD></TR></TABLE>
I diasagree
Old Dec 18, 2003 | 06:19 PM
s2000RiCeR's Avatar
F20C vtec is the loudest
Old Dec 18, 2003 | 07:59 PM
Hondatec38's Avatar
Default Re: (s2000RiCeR)
All that noise is created by the overlap of intake and exhaust valves during VTEC. The F20C clearly has more overlap than most B series motors. For example, what would be louder? A GM 350 with a stock cam, or a GM 350 with a cam that barely idles the car? Proof is in the numbers friends. Obviously variables need to be taken into consideration. Stock air cleaners are a huge variable. On a 1999 Civic Si with a B-16, the air cleaner assembly is made by Siemens. Where as the F20C assembly is made by Hitachi. Exhaust too. The S2000 has an exhaust system that was designed by Mugen and produced by Sankei. The Si was designed by Honda and produced by Sankei. Just goes to show how much Honda relies on the reliability of other manufactures.
Old Dec 18, 2003 | 09:18 PM
Champ R's Avatar
Default Re: (Hondatec38)
If we are talking stock cars here (motor, header, exhaust) then the B18C5 in the ITR is by far the loudest. Ive driven both the s2k and my brother's 99 SI, the SI being very quiet, and the s2k below when my car was stock.
Old Dec 18, 2003 | 09:32 PM
that guy steveee's Avatar
Default Re: (Champ R)
F20C is way louder than any vtec anywhere!
Old Dec 19, 2003 | 08:43 AM
chidoks's Avatar
Default Re: (simann)
H22...that thing sounds like its ripping the ground to shreds
Old Dec 19, 2003 | 09:18 AM
gots2k's Avatar
you guys crack my **** up, who cares?
My brother had a Ford Granada "back in da day" that he cleanly hack-sawed the muffler off of, that was WAAAYYY louder than my F20c's VTEC crossover point ever has been.....maybe you need a Granada
Old Dec 19, 2003 | 10:54 AM
ChargedLude97's Avatar
Default Re: (chidoks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chidoks &raquo;</TD></TR><TR><TD CLASS="quote">H22...that thing sounds like its ripping the ground to shreds</TD></TR></TABLE>
Old Dec 19, 2003 | 11:10 AM
DsITR's Avatar
Default Re: Comparing an s2000's vtec noise to a b16a2 - louder? Quieter? (gots2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gots2k &raquo;</TD></TR><TR><TD CLASS="quote">you guys crack my **** up, who cares?
...agreed
Are you saying that the deciding factor of which car you will buy...depends on how loud it is
Old Dec 19, 2003 | 01:49 PM
SpoonSpecR's Avatar
My brother had a Ford Granada "back in da day" that he cleanly hack-sawed the muffler off of, that was WAAAYYY louder than my F20c's VTEC crossover point ever has been.....maybe you need a Granada </TD></TR></TABLE>
True! Who cares!
But your no smarter for trying to compare the sound of the VTEC engine to your brothers EXHAUST. Apples and Oranges homeboy!
Old Dec 19, 2003 | 02:22 PM
gots2k's Avatar
Default Re: Comparing an s2000's vtec noise to a b16a2 - louder? Quieter? (SpoonSpecR)
umm...I...um, think you missed the point.
From the discussion above I'm thinking maybe someone needs to sell a pre-recorded INTAKE sound and have it play through a big loudspeaker under the hood, yeah, then you can guarantee you have the loudest sound coming from the FRONT of your car imaginable!!!
maybe I just don't get it.....
Old Dec 19, 2003 | 04:42 PM
DsITR's Avatar
maybe I just don't get it.....</TD></TR></TABLE>
In this case...that is a good thing
Old Dec 24, 2003 | 07:21 PM
TurboS2000's Avatar
the reason why the hatch was louder than the s2000 was because more than likely it had performance cams like skunk, toda etc. The loudest of all vtec engagements has to be the NSX the ITR and S2K are pretty close to each other, every other falls after.
Old Dec 25, 2003 | 01:19 AM
hitvtecgetloud09's Avatar
Default Re: (TurboS2000)
ever heard a nsx....now that fother mucker is load!!!!
Old Dec 25, 2003 | 11:04 AM
taikahn's Avatar
Default Re: (hitvtecgetloud09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitvtecgetloud09 &raquo;</TD></TR><TR><TD CLASS="quote">load</TD></TR></TABLE>
Its LOUD, like in your screen name... Not load, as in "This thread is a load of ****."
Old Dec 25, 2003 | 11:08 AM
EpDarks's Avatar
Default Re: (taikahn)
I vote H22A as well. However I have never ridden in an S2k.
Old Dec 26, 2003 | 11:01 AM
fuck honda-tech's Avatar
Default Re: (EpDarks)
i vote ricer!
Old Dec 26, 2003 | 12:49 PM
roadawg's Avatar
Default Re: (epsom salt)
I vote who cares?
It's all about the mods you have. exhaust, cams etc...
I guarantee my VTEC is louder than my bro's s2000.
Why? Because his s2000 is bone stock and, well my car isn't.
