stupid b16 swap ?
hey guys one question may be really really dumb... i have an si crx and to wire a b16, do i use this harness, and then does the pr3/pw0 ecu plus right in? and does everything just plug right up? can i use the si dizzy? i dont know anyhting about dohc swaps...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by firstgenrex »</TD></TR><TR><TD CLASS="quote">hey guys one question may be really really dumb... i have an si crx and to wire a b16, do i use this harness, and then does the pr3/pw0 ecu plus right in? and does everything just plug right up? can i use the si dizzy? i dont know anyhting about dohc swaps...</TD></TR></TABLE>
use your si harness, plugs right into the ecu. use the b16 distributor. all you have to do is add four wires for vtec, oil pressure, knock and 2nd 02. everything should plug right up
Exactly what he said, no you cant use your si distributor if u want the car to run good. Lastly you need to add four little pins into those clips that plug right into the ecu.
SlowSOHC-T
Oct 31, 2006 07:32 PM
civictypenos
Apr 24, 2003 01:07 AM
yea exactly what he said
