Power steering pump making noise!! Why so early?
Old Dec 16, 2003 | 05:37 AM
Elvis1977's Avatar
Default Power steering pump making noise!! Why so early?
I have a 1998 accord 4-cyl. with 112k miles and is making a humming-light buzzing noise. WHY SO SOON??? Belt tension is perfect and is original factory power sterring pump. Anybody else with a 98-02 Accord with the same problem? Any suggestions why so soon? Driving and sterring are not a problem, just annoying noise. Thanks.
Old Dec 16, 2003 | 07:40 PM
Stripped Honda's Avatar
99-0104
Default Re: Power steering pump making noise!! Why so early? (Elvis1977)
is the fluid dirty ? did you use only honda power steering fluid in it ? if i were you i would just flush your power steering system that may cure the problem
Old Dec 16, 2003 | 07:46 PM
The_Todd's Avatar
Farts in the shower
Default Re: Power steering pump making noise!! Why so early? (Stripped Honda)
I have a 90 cord and I have a small leak in the p/s, have been meaning to get it fixed or contemplating removal...but its only a couple lbs so I might just fix it up. But when the fluid is lower than normal and the car is cold it makes a buzzing/humming sound, make sure and check your lines for your p/s and your reservoir. Also you may want to notice any fluids when and after your park level ground, uphill, and downhill. My car won't leak any p/s on uphill or level just downhill and unfortunately thats how i have to park my car. I would check the lines and if you cant find any leaks I would say flush it and start over with honda fluid. just my 2 pennies. Also does it go away after it (the fluid) warms up or all the time?
ITR184
Apr 16, 2020 07:51 AM
Brett Curtis
Jun 13, 2016 03:29 PM
sky9
Feb 25, 2011 02:40 PM
mkrieger500
Nov 21, 2010 12:09 AM
questseek
Mar 6, 2010 09:32 PM
