91 si back up signals dont work, ***help***
Old Dec 16, 2003 | 02:58 AM
payneth's Avatar
Default 91 si back up signals dont work, ***help***
when i bought the car the backup signals did not work, fuses and everything is okay, its probably a bad ground but how would i go about finding out whats the problem?? eek this sucks! please help.
Old Dec 16, 2003 | 03:16 AM
bryant's Avatar
Default Re: 91 si back up signals dont work, ***help*** (Payneth)
undo the plasic in the back. You probley just have blown bulbs.
Old Dec 16, 2003 | 03:47 AM
AgentJam's Avatar
Could be the reverse switch on the tranny as well. It's right on top of it, just under the distributor.
Old Dec 16, 2003 | 04:07 AM
payneth's Avatar
oh i checked the bulbs as well. jus forgot to put that on the post. i will check the switch. what should i check on the tranny and when i find it what should i do to make the damn thing work, lol.?
Old Dec 16, 2003 | 06:38 AM
Alan Wil's Avatar
Default Re: (Payneth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Payneth &raquo;</TD></TR><TR><TD CLASS="quote">oh i checked the bulbs as well. jus forgot to put that on the post. i will check the switch. what should i check on the tranny and when i find it what should i do to make the damn thing work, lol.?</TD></TR></TABLE>
Most likely cause is the reverse light switch, or the wires to the switch becoming disconnected /bad fuse, etc. Blown reverse light bulbs are rare since the amount of time spent in reverse is so small. Check at the fixture itself to see if they have power and ground. If not jumper the reverse light switch. It’s located on the trans.
PS: Do you have a SERVICE MANUAL for the car? If not that’s the FIRST thing you need to source before doing anything.
Old Dec 16, 2003 | 04:33 PM
payneth's Avatar
thanks i will check out my honda book.
twistedek
Nov 18, 2008 07:34 PM
eghatchin
16
Apr 25, 2008 04:46 PM
wardseg6
Dec 27, 2007 05:52 PM
krazyDOHC
27
Aug 18, 2003 04:24 PM
B_CRUZ!
Nov 6, 2002 11:46 AM
