Brembro brakes + crap pads. Too late to change?
Got a question, I got brembro cross drilled /slotted on the front, but at the time I was in a severe situation where I needed my car out immediately so I had to get autozone 30 "performance" brakes.
Well anyways, i know its autozone brakes, just curious, ive had my brakes on for about 5k miles, is it too late to switch brake pads now ? Uneven wear will happen I assume ?
Because i cant really get the rotors resurfaced....
I wouldn't worry about it. With my Wilwoods, I change the pads all the time and NEVER get the rotors turned. Never had a problem with glazing or cracking. Seasoned rotors tend to be a better bedding surface anyway.
Why can't you get the rotors turned? What pads are you planning on using?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDA9 »</TD></TR><TR><TD CLASS="quote">
Why can't you get the rotors turned? What pads are you planning on using?</TD></TR></TABLE>
Thinking about getting green stuff.
I gotta bleed the brakes too, that should be fun.
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chemicalviper »</TD></TR><TR><TD CLASS="quote">
I gotta bleed the brakes too, that should be fun.</TD></TR></TABLE>
Ewwwww green stuff!
I say go Axxis Ultimates.
My friend had Green stuff on his gsr, and they fade really nasty, as well as tore the **** out of his rotors.
Ewwwww green stuff!
heh, well green stuff out.
Im just curious will it be fine to change them like 5/6k miles after i put other ones in ?
I am not gonna get uneven wear ?
yeah your brakes should be fine. hey i got a question. i want to go with a 17 inch rim but im wondering if i have to upgrade to a big brake or can i just put drilled rotors and ceramic pads on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
You can just put drilled rotors on, but its just going to hurt your braking performance.
Drilling / Slotting + stock sized rotors =
skimeast1982
Oct 18, 2006 04:31 AM
Trellis
Mar 12, 2003 04:50 PM
You shouldn't have any problems switching just the pads. I've done that many times on other cars without any problems.
