Need help on dx harness to b16 (1st gen)
i found out to wire it up exsept the dizzy. theres 5 wires on a dx harness and 7 wires on the b16. the main plug is different. what do i do??? need help asap!
I cut the DX harness dizzy plug and spliced it into the Si dizzy plug. All wires are the same color from one plug to another. There will be 2 wires left over and they are both white. Run one wire to pin C1 and one wire to pin C2. There have been posts about this before, remember Search is your friend, it will help you out alot
Guys correct me if I said something wrong
Here is what you do... if you converted the dx harness to mpfi swap. There were two wires you brought into the interior of the car for the crank angle sensor. The rest of the wires you unplug from the harness and 5 with 5. Just swap out the wires by color. You should be set from there.
elmalouno
Apr 11, 2009 04:48 PM
xXSilentScreamXx
19
Aug 11, 2007 01:41 PM
88rexdxa6ed
May 9, 2003 04:28 AM
