Spoon Fan Switch
Old Dec 15, 2003 | 02:10 PM
ArmyGreenITR's Avatar
Default Spoon Fan Switch
Do you need the spoon fan switch when you have the thermostat and raditor cap?
thanks in advance
Old Dec 15, 2003 | 02:12 PM
TypeR 599's Avatar
Default Re: Spoon Fan Switch (ArmyGreenITR)
You don't have to. The switch will just help make it cooler on top of what the thermostat will already do.
type r 01-1063's Avatar
Nope. They all work independently
Old Dec 15, 2003 | 02:20 PM
Default Re: Spoon Fan Switch (type r 01-1063)
Ok thanks,i was just asking because a friend of mine works at a performance shop that is going out of bussiness he offered me cost on some stuff,my thermostat has been acting up so i bought the Radiator cap and the thermostat,i didnt know if i needed the switch or not.
Old Dec 15, 2003 | 02:21 PM
TypeR 599's Avatar
It might be too cold if you use the switch with the spoon stat, but why not? You're getting it at cost, sell it on h-t hah
Old Dec 15, 2003 | 02:26 PM
Rboosted717's Avatar
Yes the fan switch does help on top of the thermostate. In bumper to bumper traffic the fan switch is nice since it helps cooling while the radiator isn't getting much air from slow movement.
Click the link in my signature for tons of Spoon items I'm selling. All the Spoon items are in great condition and are way under retail and probably cost.
Old Dec 15, 2003 | 02:33 PM
Bbasso's Avatar
IS there any beifit to add the Spoom fan switch to a stock R?
Old Dec 15, 2003 | 02:37 PM
B2FiNiTY's Avatar
Default Re: Spoon Fan Switch (Bbasso)
Yes, your fan will come on more often to cool down the motor.
I do not recommened using the Spoon thermostat unless the car is a 100% track car because it simply runs too cold on the street and highway(freeway).
If your going to install everything, might as well get the thermoswitch.
Get the mugen one because it is the same thing as the spoon but costs a ton less.
Old Dec 15, 2003 | 06:05 PM
Mike M's Avatar
Founding Member
Default Re: Spoon Fan Switch (B2FiNiTY)
I actually only reccomend using the Fan Switch or the Thermostatm no Both together.
Reason being they make the car run too cold and cause problems. Most common problems: VTEC will not engage as the car thinks it has not warmed up as well as the car running a richer fuel curve.
A few members running both parts together have experienced this including Yoshi and Austin.
For a Race Only car run both. For a street/race car run one or the other.
Old Dec 16, 2003 | 10:23 AM
Default Re: Spoon Fan Switch (Mike M)
Thanks for the insight guys
SpoonEk253
Aug 30, 2005 11:21 PM
SpoonEk253
Northwest (Sales)
Aug 27, 2005 01:40 PM
SpoonEk253
Aug 27, 2005 01:39 PM
ithrowpoop
Apr 3, 2002 05:14 PM
