Main Relay EF vs. DA
Old Dec 15, 2003 | 12:41 PM
SqueezinEF's Avatar
Default Main Relay EF vs. DA
Can someone confirm or deny if the main relay from an 88-91 Si EF is interchangeable with a 90-93 DA?
I have both cars with main relay problems. I can find an EF main relay but not a DA relay. Two people told me that they are interchangeable. I just want to make sure before I buy again.
I know I can just take the civic one out and try it out in the integ, but just wanted to see if I could get an answer without doing the work.
TIA, Chris
Old Dec 15, 2003 | 12:48 PM
Perfectionist's Avatar
Default Re: Main Relay EF vs. DA (SqueezinEF)
Not familiar with a "DA vs EF", but if you've got the relay out, just pop off the cover and re-solder the joints on the circuit board. That's where 99% of the trouble comes from...cracked solder joints. BTW, if the contact configuration matches the plug, it is most likely correct for the application.
Old Dec 15, 2003 | 03:37 PM
SqueezinEF's Avatar
Default Re: Main Relay EF vs. DA (Perfectionist)
DA = 90-93 Integra
EF = 88-91 Civic
I know that if I look at them I will figure it out. I am just checking to see if anyone else knows about this already so that I don't have to take apart both cars to figure it out. I will if I have to, but just checking if anyone here already knows. Thanks though. BTW, I hate the main relays in both cars.
Old Dec 16, 2003 | 06:49 AM
SqueezinEF's Avatar
They are exactly the same for anyone who wants to know also.
Old Dec 16, 2003 | 10:50 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SqueezinEF &raquo;</TD></TR><TR><TD CLASS="quote">They are exactly the same for anyone who wants to know also.</TD></TR></TABLE>
Yes, they are, I have both. The 2G tegs main relay is up behind the coin tray.
DA3
Jan 5, 2011 06:21 PM
efjones9
Jun 1, 2009 09:35 AM
lmananT
Jun 7, 2008 06:43 AM
BolivianFuego
Oct 30, 2006 08:26 AM
