Need help fast!! gsr cluster install gone wrong.............
Old Dec 15, 2003 | 11:11 AM
ICeDoUt's Avatar
Default Need help fast!! gsr cluster install gone wrong.............
so i tried to install it today on my 90 hf with this write up:
here is the wiring diagram that I used. Worked perfectly. Just remember that you need an electronic VSS. Make sure that you hookup the vss wire from the ecu to the cluster. If i remember the ecu to vss wire on the 90-91 civics is wht/red. This wire needs to be tapped into the orange wire in order for the ecu to receive signals from the VSS. BTW you need to go by the location and the wire color. Both are important as different plugs may have the same wire coloring. If you have any questions PM me.
1990-91 CRX:
12 pin connector:
1) Blue-tach
2)White/Blue-Volts
3)Black/Yellow-12v power
4)green/Orange-Check Engine
5)yellow/Red-Oil Light
6)Green/Red-E brake
7)Green/Red-Door Light
8)Red-Dash-Dash Lights
9)Red/Black-Dash Lights
10)Yellow/Green-Water Temp.
11)red/Blue-High beam
12)Green/Blue-Turn Signal Left
8 Pin connector:
1)Green/Yellow-Right Turn Signal
2)Yellow-12v Power
3)Yellow/white-Feul Gauge
4)Not Used
5)Green/black-Trunk light
6)Not used
7)yellow/red-Speed sensor
8)Black-Ground
94-01 GSR:
13 Pin connector:
1)Blue- Tachometer
2)Geen/Orange-Check engine
3)Yellow/Orange-Oil Light
4)Not Used
5)White/blue-Volts
6)not used
7)Yellow/green-Water Temp.
8)black-ground
9)Red/Blue- cruise(not used unless you have it)
10)Yellow-12vPower
11)Not Used
12)Not Used
13)Not Used
16 Pin connecter
1)Green/red- E brake
2)red/Green-High Beam
3)Green/Yellow-Right Turn signal
4)Green/Blue Left turn signal
5)not Used
6)black/yellow-12vPower
7)Red/Black-Power
8)Red-12vpower
9)blue/Red-ABS(not used unless you have it)
10)green-Trunk Light
11)Orange-VSS
12)not used
13)Blue/White-Low Feul(not used unless you have it)
14)Yellow/white-Feul Gauge
15)Green/Red-door
16)red/blue-seat belt
But......... Now my car won't start, just cranks. Turn signals don't work but according to above they are correct. The only thing i can tell that is actualy right is the highbeams and e-brake. Can the vss with a bad ground cause this? my fingers hurt form twisting and soldering wires all day, anyone with any help????
Old Dec 15, 2003 | 02:30 PM
ICeDoUt's Avatar
Default Re: Need help fast!! gsr cluster install gone wrong............. (ICeDoUt)
my dumb *** blew a fuse, starts but still no tunr signals/speedo, all wires hooked up acording to above.
Old Dec 15, 2003 | 02:38 PM
APEX CRX's Avatar
hey you know I'm about to do Type R cluster swap into my 89 CRX Si, question for you is the wiring the same as your 90? also I got a diagram from Ghettocrxsi. he's the man when it came to these swaps. he was the first person i saw here on HT to do the swap. he has diagram on this page:
http://angelfire.com/dc/oregonimport/gsr.html
the diagram for the wires are a bit different?
Old Dec 16, 2003 | 02:30 PM
ICeDoUt's Avatar
Default Re: Need help fast!! gsr cluster install gone wrong............. (APEX CRX)
yea i got it figured out, i had to look up some schematics thought. I messed up the VSS wiring, and had the illumination all mesed up, but tis in and everything works!
Old Dec 16, 2003 | 02:38 PM
APEX CRX's Avatar
cool, get a pic up so we can see it !!!! I'll post one when i finally get around to doing mine
USDMSiR
15
Aug 31, 2006 02:07 PM
Zatzy
Mar 15, 2006 01:46 PM
EF8IGHT
Feb 14, 2006 09:11 AM
2kTeg
Mar 30, 2005 04:56 AM
ironchef25
16
Aug 26, 2004 06:55 PM
