Will 14's fit my GSR?
Old Dec 15, 2003 | 08:59 AM
YellowGiser's Avatar
Default Will 14's fit my GSR?
What the topic says...I am buying steelies for winter for my gsr and alot of people told me I will need spacers because of my brakes.
Old Dec 15, 2003 | 09:02 AM
NastyGsr94's Avatar
Default Re: Will 14's fit my GSR? (YellowGiser)
They should fit on with no problem
Old Dec 15, 2003 | 09:09 AM
Default Re: Will 14's fit my GSR? (NastyGsr420)
did you try it?
Old Dec 15, 2003 | 09:23 AM
96dc2's Avatar
Do you have stock brakes?
Old Dec 15, 2003 | 09:43 AM
Default Re: Will 14's fit my GSR? (96dc2)
yes stock gsr brakes
Old Dec 15, 2003 | 10:04 AM
riceball777's Avatar
if you have stock brakes 14's will fit fine
many stock integra's such as thr rs and onler ls modeles come with 14's
if you have an itr or 11" rotors you will need at least 15's
Old Dec 15, 2003 | 10:11 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Will 14's fit my GSR? (riceball777)
I have a stock '94 GS-R and am using a set of Tire Rack 14" steel wheels with Blizzaks. Without spacers.
So I think the answer is "yes".
Old Dec 15, 2003 | 10:44 AM
quikB18B's Avatar
Default Re: Will 14's fit my GSR? (nsxtasy)
Yes they will fit, 13" steelies would require modification because they would rub the brakes. I used my steelies from my first car 91 ls (14") on my last gsr(96) with no probs. I think most g3 owners run 14" steelies because there easier to find than 15".
Old Dec 15, 2003 | 11:50 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: Will 14's fit my GSR? (quikB18B)
I will answer for you, YES, I had them on my car for 2 months before gettin my set of rotas. They fit but do not take turns very fast. Its a lil scary at times.
Old Dec 15, 2003 | 11:56 AM
Huh_oh Shit!'s Avatar
YES they do fit. My GSR came with 90-93 GS rims which are 14". i have no money yet to upgrade to better wheels, so i have to deal with these for now.
Old Dec 15, 2003 | 11:59 AM
89hatchback's Avatar
Default Re: (Huh_oh ****!)
yes 14s will fit, i have 93 integra brakes on my civic and i have 14" steelies/
Old Dec 15, 2003 | 12:04 PM
sPaRk'iT's Avatar
Yes it will fit with no mods if you have stock brakes.
Old Dec 15, 2003 | 03:23 PM
Default Re: Will 14's fit my GSR? (sPaRk'iT)
thanks alot guys for all the responses
Old Dec 15, 2003 | 03:31 PM
black sohc civic's Avatar
14s will rub the brakes if you have GSR brakes at least in my experience
either get a 12mm spacer or grind down the calipers is what I did to make HX wheels fit
Old Dec 15, 2003 | 03:35 PM
TeamSTEALTH GSR's Avatar
Default Re: Will 14's fit my GSR? (black sohc civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black sohc civic &raquo;</TD></TR><TR><TD CLASS="quote">14s will rub the brakes if you have GSR brakes at least in my experience
either get a 12mm spacer or grind down the calipers is what I did to make HX wheels fit</TD></TR></TABLE>
he said 14" steelies.. 14" HX are a different story...
steelies fit. GSR , LS = same caliper/rotor
Old Dec 16, 2003 | 05:12 AM
Default Re: Will 14's fit my GSR? (TeamSTEALTH GSR)
Gsr have bigger breaks from what I know (than ls)
Old Dec 16, 2003 | 06:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowGiser &raquo;</TD></TR><TR><TD CLASS="quote">Gsr have bigger breaks from what I know (than ls)</TD></TR></TABLE>
yeah, i thought GSR's have bigger brakes? i got 14" steelies that rubbed in the front of my GSR.
Old Dec 16, 2003 | 06:37 AM
db8sirg's Avatar
yeah, i thought GSR's have bigger brakes? i got 14" steelies that rubbed in the front of my GSR.</TD></TR></TABLE>
all g3 integra have same brake except itr.
Old Dec 16, 2003 | 06:41 AM
GotGSR's Avatar
Default Re: Will 14's fit my GSR? (db8sirg)
the hx rims are 13's arent they?
Old Dec 16, 2003 | 07:57 AM
96dc2's Avatar
Default Re: Will 14's fit my GSR? (GotGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GotGSR &raquo;</TD></TR><TR><TD CLASS="quote">the hx rims are 13's arent they?</TD></TR></TABLE>
HX are 14's, VX are 13's.
Old Dec 16, 2003 | 08:02 AM
jdmintegra1994's Avatar
I have 14" steelies and they rub the brakes. When i press hard on the brake, you can feel/hear them rubbing. It's not that bad tho.
Old Dec 16, 2003 | 10:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8sirg &raquo;</TD></TR><TR><TD CLASS="quote">
all g3 integra have same brake except itr.</TD></TR></TABLE>
Old Dec 16, 2003 | 10:40 AM
IntEGNYC's Avatar
should fit with out any problems
Old Dec 16, 2003 | 10:50 AM
furious94ls's Avatar
Default Re: (IntEGNYC)
All G3 LS/SE/RS/GS/GSR have the same rotors, and calipers. 14 inch steelies fit fine on the GSR. I have them now for the winter.
Old Dec 16, 2003 | 12:43 PM
Mt3c's Avatar
25 Year Member
Note.
the people that may have rubbing problems could be using steelies from civics, which are 14x5 for most years.
The ones that came stock on 94+ integras are 14x5.5.
just in case i'm wrong, i suggest running a search.
