Anybody measured the pressure drop across the stock DC2 airbox?
Old Dec 15, 2003 | 08:35 AM
IN VTEC's Avatar
Default Anybody measured the pressure drop across the stock DC2 airbox?
I was wondering if anybody had done this before to save me the work.
If you have, list what filter you used.
Old Dec 15, 2003 | 08:12 PM
motoman's Avatar
Default Re: Anybody measured the pressure drop across the stock DC2 airbox? (IN VTEC)
Stock filter:
pressure drop right before throttle body = ~45 cm water
with snorkel removed = ~30 cm water
pressure drop in the resonator box with no snorkel = ~15 cm water
The tubing I used was the clear kind you can get at home depot, inner diameter = ~4-5 mm.
All readings were taken around redline at WOT, sort of hard to get it exact reading while driving.
The filter itself really does not cause any pressure drop. Thats why drop in filters dont really do much.
Old Dec 15, 2003 | 08:52 PM
IN VTEC's Avatar
Default Re: Anybody measured the pressure drop across the stock DC2 airbox? (motoman)
Thank you very much for the info. Just a few questions to clear some things up in my head.
By snorkel, you mean the J-tube where it draws air in from the fender area?
Were you referencing from the beginning of the intake piping or from atmospheric pressure?
I'm guessing for the filter pressure drop test, you just took off the airbox lid?
Old Dec 16, 2003 | 12:46 AM
motoman's Avatar
No, the snorkel is the tube that connects from the resonator back into the engine bay, which draws air from behind the abs unit.
This is in relation to atmospheric pressure.
For the filter test, you can snake the tube into the airbox from the intake, and take a reading there, and then snake the tube from where the engine breather vents into the intake, to the airbox, and take a reading there.
lostforawhile
Jul 26, 2014 02:24 PM
Silvertc
Oct 14, 2009 09:56 AM
scvludedood
Apr 27, 2009 08:06 PM
xDicktonesx
Nov 17, 2006 10:59 AM
klrskies
May 6, 2004 10:31 AM
