S2000 Oil Filter...
Has anyone used an OEM s2000 oil filter on an ITR. A friend at the local Honda dealership told me to use the s2000 filter because it would be better for the B18c5 motor. Thoughts?
dont no if its better but i no u can use it i heard that the new one is better for the b18c5 because they have low oil press so the new oil filter is smaller so it gives u more oil press thats what i heard
Your friend probably told you this because the s2k filter is the only one that didn't change to the new smaller higher oil pressure design.
My local honda dealer wanted $10.99 for it
I did some searching and found out that Filteh makes Bosch now so thats what I switched to. Do some searching under oil filter, theres tons of info on the new change
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B »</TD></TR><TR><TD CLASS="quote">Your friend probably told you this because the s2k filter is the only one that didn't change to the new smaller higher oil pressure design.
</TD></TR></TABLE> well we get it for $7 over here on the island and yeah the s2k is the only one that didint change
the new s2000 filter supposed to be the same size as POH filter, which was discontinued and probably not easy to find by now.. if i ever need to re-supply my filters, i'd probably go for s2000..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">Works just fine, have one on my car now
How would u know if it wasnt working fine
j/k
</TD></TR></TABLE>How would u know if it wasnt working fine
j/k
