How do I read tire size?
Old Dec 15, 2003 | 12:55 AM
dc2lun's Avatar
Default How do I read tire size?
How do I read tire size? What does each number mean?
Old Dec 15, 2003 | 01:01 AM
acteg94's Avatar
Default Re: How do I read tire size? (dc2lun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2lun &raquo;</TD></TR><TR><TD CLASS="quote">How do I read tire size? What does each number mean?</TD></TR></TABLE>
for example: 205/45/16
205 is the width of the tire, other number 185/195 the higher you go, the wider it is
45 is how thick the tire is, there is 35/40/55 now the lower you go, the thinner it is
16 is just the wheel size, there is 14/15/16/17/18/ even 26's damn
Old Dec 15, 2003 | 03:10 AM
PhatboyNYC's Avatar
Default Re: How do I read tire size? (acteg94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acteg94 &raquo;</TD></TR><TR><TD CLASS="quote">
16 is just the wheel size, there is 14/15/16/17/18/ even 26's damn</TD></TR></TABLE>
Just a clarification:
The middle number (45 in the above example) is a profile ratio based on the width of the tire. This is calculated by taking the % (45) of the width (205) = 92.25.
Unlike the width and wheel size which are independent of each other, the actual tire profile all depends on the width of the tire.
So a 215/45/16 tire would actually have a bigger sidewall profile than a 205/45/16 tire. The key in upsizing wheels is to try and maintain the same overall diameter as the stock wheel so you don't throw off your speedometer and odometer readings.
Old Dec 15, 2003 | 05:30 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: How do I read tire size? (PhAtBoY Si)
http://www.tirerack.com/tires/...l.htm
Old Dec 15, 2003 | 11:07 AM
Jimmy's Avatar
Global Moderator
Nice info
Old Dec 15, 2003 | 02:39 PM
dfoxengr's Avatar
Default Re: How do I read tire size? (USDMDC2)
all are in mm too. exceept the 15/16 which is inches
Nbboy7
Apr 12, 2008 05:38 PM
Platinum.Skillz
Oct 31, 2007 11:52 AM
realis9
Jul 9, 2007 09:30 AM
sain167
Jul 21, 2004 08:06 AM
xunkn0vvnx
Sep 18, 2002 07:04 AM
