need help with carsound cat and O2 sensor ...
ok, i have 2000 gsr w/ a jdm type r header, 2.5 carsound cat and exhaust. well, the other day, the check light came on. assuming that its just a minor glitch, i reset the ecu and the check was off. after 2 days, it came back on and a buddy of mine helped me check for the code and he told me it was either the carsound cat or the O2 sensor was throwing the code. i want to know if there is a way to check to see if its the cat or the O2 sensor that is down b4 i start buying parts for the replacement. anyone have any recommmendation on the replacement parts? thanks
A cat won't throw a code, only sensors and electronics will. Let us know the code first before you just assume its the cat.
According to what you said, code 67 is the Catalyst System
Found here: http://www.team-integra.net/se...ID=34
I found this Article On T-I.net
http://www.team-integra.net/se...lator
http://www.mkiv.com/techarticl....html
Modified by 96 Ls lnTeG at 12:22 AM 12/16/2003
doubleoazn03
Mar 3, 2018 02:06 PM
