b16a2 into 5g hatch mount question
Old Dec 14, 2003 | 09:29 PM
Odiedogcx's Avatar
AIRBORNE
Default b16a2 into 5g hatch mount question
my friend just got his "complete" b16a2 for his 92 Si hatch. Only thing it was missing was the driver side mount.
Can he use the d16 mount? Or does he need to the b16 mount? What are his options? Thanks
Old Dec 16, 2003 | 08:16 PM
doublejz's Avatar
Default Re: b16a2 into 5g hatch mount question (Odiedogcx)
the mount from the d16 should work, worked on mine. the rear is def. different though
Old Dec 18, 2003 | 09:41 AM
Scott - 93HB Si's Avatar
if you D16 is a 92-93 (Black upper mount) you'll be fine. If your car is a 94-95 Si you will have a silver mount on teh driver's side - same as the integra, and you will either need to swap the block mount, or get the proper D mount.
civicsiguy21
Apr 10, 2014 04:06 AM
vtecthiss
Sep 7, 2008 09:51 PM
90redintegra
Dec 8, 2006 06:17 AM
