help with ride height and wheel size
i was planning on putting my old wheels off of my crx onto my new hatch and i was wondering something. the hatch has 13" steelies on it now and the crx's wheels are 14x6 with a 195/65/14 tire and i was wondering if i put these wheels/tires on will it make it look higher or lower??? I LOVE the way it sits right now on the 13's, its just sooooo low and doesn't bottom out, so i wanna keep the same height. tia
It will probably sit a little bit higher with the 195 65 14's considering stock tire size for the Si's are 185 60 14's. So if you put those on it will probably be a bit higher use this link http://www.miata.net/garage/tirecalc.html enter in your 13" tire size and then the 14" size and you will find out the difference and also you can find out what size tire you would need for it to be the same height sicne if you keep the diameter the same it will be the same height.
JuneBugDrfter
Jul 18, 2010 12:16 PM
