Changing pistons
Old Sep 20, 2001 | 06:38 PM
BABY NSX's Avatar
Default Changing pistons
Does changing the pistons require the engine to be re-balanced?
Specifically when moving up to higher compression JDM or better pistons.
Also what are peoples experiences here with different pistons and Toda spec-A,B or spoon cams?
Thanks,
Old Sep 20, 2001 | 06:54 PM
mugenr#1011's Avatar
Default Re: Changing pistons (BABY NSX)
good questions... im not to sure, but maybe if you buy balanced pistons you should'nt have to. hell i might be wrong!! i would'nt think so though......mugen
Old Sep 20, 2001 | 07:00 PM
BABY NSX's Avatar
Default Re: Changing pistons (mugenr#1011)
...but maybe if you buy balanced pistons you should'nt have to.
I tend to agree if all aftermarket pistons are balanced to the same weight! But are they?
Either way I'd like to know if people here are having their engines balanced with this type of engine change.
Thanks,
[Modified by BABY NSX, 8:02 PM 9/20/2001]
Old Sep 20, 2001 | 07:05 PM
sgT's Avatar
sgT
It is recommended that you hone the cylinder walls every time you change
the rings. Also not only should the pistons be balanced, but the rods with
the pistons, as well as the crankshaft so that the entire rotating assembly will be
balanced.
Old Sep 20, 2001 | 07:11 PM
Big Phat R's Avatar
I just installed Endyn Rollerwaves with forged Eagle rods, had the block bored out 0.5mm and had the entire rotating assembly (including flywheel) fully balanced. If high hp, high revving reliability is what you are looking for - then it is definitely recommended.
Old Sep 20, 2001 | 07:48 PM
BABY NSX's Avatar
Default Re: Changing pistons (Big Phat R)
Thanks guys, this rules out the posiblility of installing these myself!
Does the engine need to come out of the car to balance it? What is involved? Is it generaly very expensive?
Sorry for the questions.. Just trying to get an understanding of the scope of this potential upgrade!
How about ordering completely balanced kits from Toda or Spoon? Anyone have any experience with these?
Regards,
Old Sep 20, 2001 | 08:05 PM
sgT's Avatar
sgT
pull it out and tear it down.
dont waste your money on spoon
kingofbattle909
May 3, 2011 07:33 AM
ge_itr
Feb 5, 2007 06:45 PM
tegon-gsr
Jan 2, 2005 04:09 PM
