any differemces in 99-00 ex and si wiring harness?
just a quick question....... i've been looking through wiring diagrams and in my haynes manual, but i can't find any differences.... are there any? i need to do a swap in a few days (b18c1 in a 99 ex) and i'm unsure which wiring harness to start with. any input is appreciated. thanks in advance.
Modified by Team 4R at 7:42 PM 12/14/2003
There are very minor differences, if any between the 99-00 Si and 99-00 EX harnesses. You can easily reuse your stock EX harness for the swap. Whether you use it or a Si, you will still need to wire up the IAB, rewire the IAT and extend a few plugs to reach where they need to go.
okay, that's what it looks like...... thanks. a follow up question, again an answer i haven't been able to find: would i need to change the engine side plugs on the wire harness to match the gsr motor? i will have the gsr harness, so that shouldn't be a problem, but i'm not sure if it is required........ again, thanks.
S2k Hybrid
10
Feb 2, 2007 08:29 AM
Adam.
Apr 20, 2006 09:03 AM
