91 ls tranny in 93 ls
Old Dec 14, 2003 | 03:42 PM
projectTeG's Avatar
Default 91 ls tranny in 93 ls
i got a big question to ask , im doing a 5-speed swap in my ls and the only trannys i can find locally are 90-91 ls trannies, i know that they are different then the 92-93 tranny. if i was to put the 91 tranny in my car would it be worth it and could i use the 93 ls flywheel and get a 90-91 clutch set to get the tranny to wrk?
Old Dec 14, 2003 | 03:49 PM
mr.beeks's Avatar
Default Re: 91 ls tranny in 93 ls (projectTeG)
basically just match to what you are getting
a 91 flywheel and 91 tranny then you should have no trouble of
mismatch...
Old Dec 14, 2003 | 04:32 PM
projectTeG's Avatar
oh so i cant use the 93 flywheel
Old Dec 14, 2003 | 05:20 PM
Colin's Avatar
Default Re: (projectTeG)
you can use any b series flywheel. They are interchangable, only significance is weight (itr is lighter).
Make sure you get a 90-91 integra clutch, the 92+ b series clutches will not work.
Thats all ya gotta do
kyleviney91da
May 25, 2007 08:31 AM
Blaze45
Nov 21, 2004 11:09 PM
EF Two.
Aug 31, 2004 07:48 PM
WuShu
Mar 6, 2002 07:37 PM
