Ignition: Troubleshoot - no spark
Old Dec 14, 2003 | 02:30 PM
GQ Cowboy's Avatar
Default Maybe you guys might know, no spark at sparkplugs
I can't start my car. The engine will turn over with no trouble, but when i pulled a spark plug with the wire still connect and tried starting the car - there is no spark. The car was running fine a couple of days ago, its been 2 day since I tried to start it, but today - it won't fire. Could it be a bad distributor?
Does anyone know what might be the trouble?
Old Dec 14, 2003 | 02:33 PM
Kendall's Avatar
Yes it could be a bad distributor or maybe just one bad distributor part. Check it out.
Old Dec 14, 2003 | 04:24 PM
EKJUNKY80's Avatar
Default Re: Maybe you guys might know, no spark at sparkplugs (GQ Cowboy)
might just need a new ignition coil.if u dont know,its located inside the distributor.black box looking thing.ive had to replace a few already.
but try that first its cheaper than replacing the whole distributor.
Old Dec 14, 2003 | 05:11 PM
GQ Cowboy's Avatar
Default Re: Maybe you guys might know, no spark at sparkplugs (EKJUNKY80)
Well, I got the distributor back in May of this year. Went back, got a new one under warranty, and installed correctly. The car will will not spark. I can't figure it out. I have checked numerous times all the fuses = okay. I'm not sure what happened? Any other ideas to what the problem might be?
Old Dec 14, 2003 | 05:26 PM
Stunna BEN's Avatar
Don't call it a comeback
Check all of your grounds
Old Dec 14, 2003 | 05:29 PM
Good ol' Screwtape's Avatar
Multi-paradigm
coil your ignitor.
Old Dec 14, 2003 | 05:33 PM
GQ Cowboy's Avatar
Default Re: Maybe you guys might know, no spark at sparkplugs (-BEN-)
checked grounds.... still no luck with the sparks plugs: no spark. I have no idea. sucks really bad.
Old Dec 14, 2003 | 06:58 PM
Stunna BEN's Avatar
Prolly coil then
Old Dec 14, 2003 | 08:25 PM
esponet's Avatar
check to see if you got power at the coil. you could also do a resistance check on the coil to see if it is good or bad, you could also look into your igniter.
Old Dec 14, 2003 | 08:52 PM
Tommy_Gunns's Avatar
Of course there is no spark if it doesn't have a ground to arc to.
Your block is ground for the spark plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GQ Cowboy &raquo;</TD></TR><TR><TD CLASS="quote">when i pulled a spark plug with the wire still connect and tried starting the car - there is no spark.</TD></TR></TABLE>
Old Dec 14, 2003 | 09:55 PM
GQ Cowboy's Avatar
Default Re: Maybe you guys might know, no spark at sparkplugs (Tommy_Gunns)
Its running, to all those how care. it was the ACG fuse. I don't think it has a number, but after replacing this one. the car started up. Thanks for all those who helped.
Modified by GQ Cowboy at 11:48 AM 12/15/2003
Modified by GQ Cowboy at 10:50 AM 12/16/2003
Thecargoddess
Jul 3, 2024 07:09 PM
crxion91
Jan 19, 2008 12:35 PM
CptCorN
Jan 17, 2005 06:33 AM
widecoupe
May 12, 2002 11:34 AM
