DIY accord camber washer trick question
Old Dec 14, 2003 | 06:00 AM
boiwitwhitehond's Avatar
Default DIY accord camber washer trick question
i am gonna drop my car 1.8 inch...on stock Ex rims with 195/65/15 tires..and imma do the washer trick to fix my rear camber....DO YOU THINK i can still have ppl sit in the back of my car without the tires rubbing again that ARM thats above the tires?????..im using 2 washer per bolt..and HAS ANYONE done this TRICK before?...DOes it work?? 96 accord 4 dr
thanks
Old Dec 14, 2003 | 06:05 AM
KTeller8's Avatar
Default Re: DIY accord camber washer trick question (boiwitwhitehond)
i have 96 accord and dropped it 2" and i used an ingalls full system, basically they sent me the same damm thing
the front were nice but the rear was the screw and some washers..
anyways. i have no problem, and i seem to carry around a big fat *** freind.. who sits in the back
Old Dec 14, 2003 | 08:42 AM
whoa its len 2's Avatar
2 washers per bolt for me. I used to have rear camber wear till I added the washers. New tires and 6000 miles later, little to no camber wear on the rear. Too bad I cant say the same for the fronts.
Old Dec 14, 2003 | 06:48 PM
accordfreak's Avatar
Default Re: DIY accord camber washer trick question (whoaitslen2)
i forgot, what was the bolt and washer size you're supposed to get??
redraif
Aug 20, 2015 06:34 AM
dubarry
Aug 18, 2011 09:12 AM
kgoner45
Apr 3, 2007 03:03 PM
verbal
Sep 22, 2004 09:14 PM
h22accordturbo
Apr 21, 2003 11:38 AM
