92-95 Civic Four Door front lips?
ok, four door civic appearance parts are hard to come by. especially things like front lips... My friend has a stock 99-00 Civic Si front lip on his 4dr and it fits like a glove. has anyone else with a four door try fitting any other lips to thier bumpers?
I was considering buying a JUN knockoff lip for a 99-00 civic and seeing if it will fit since the stock si lip fits...
i think te Spoon Sports carbon fiber frnt lip shoul fit. Get the one meant for the EG6 Civic (92-95). The bumpers are different, but since the lip goes connected to the bottom, i dont see y it shouldnt fit. try any of these sites to find it:
IPSracing.com
JDMhondaparts.com
Inlinefour.com
PasswordJDM.com
TakaKaira.co.jp
IPSracing.com
JDMhondaparts.com
Inlinefour.com
PasswordJDM.com
TakaKaira.co.jp
The only thing I really don't like about the 4dr is the front bumper. The HB/coupe bumper looks so much beter. and they do fit. There is an edge around the front wheelwell which is a bit thinner on the 4dr but if you line it up nicely it's hard to notice. And you'll need to make an extra hole for the screw in the wheelwell.
It just looks beter IMO and it increases your number of options for frontlips.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">
this is my friends 99-00 si front lip - fits like a glove.</TD></TR></TABLE>
got mines sitting in the garage! What grit sandpaper did your friend use to sand the lip down?
i have seen a pic and have been told that a 97 itr lip would work.....the pic was on here some where....was a light blue sedan with a 97 itr lip.....someone find it....looked really good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ming Tsai [foodtv »</TD></TR><TR><TD CLASS="quote">]
got mines sitting in the garage! What grit sandpaper did your friend use to sand the lip down?</TD></TR></TABLE>
im no body man but i used some real mild sand paper that is for wet sanding. just wet sanded it a lot and then hit it with duplicolor flat black. it hid a lot of the scratches that are in the lip also.
got mines sitting in the garage! What grit sandpaper did your friend use to sand the lip down?</TD></TR></TABLE>im no body man but i used some real mild sand paper that is for wet sanding. just wet sanded it a lot and then hit it with duplicolor flat black. it hid a lot of the scratches that are in the lip also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioSiR »</TD></TR><TR><TD CLASS="quote">
im no body man but i used some real mild sand paper that is for wet sanding. just wet sanded it a lot and then hit it with duplicolor flat black. it hid a lot of the scratches that are in the lip also.</TD></TR></TABLE>
Thats a phat lip yO
Thats a phat lip yO
Declectic
Aug 21, 2004 11:02 PM
Turbo D' Sol
Jan 30, 2004 03:21 PM
kay_animation
Jan 10, 2003 10:26 AM
