What is wrong with Unorthodox Racing (UR) crank pulleys ?
are the ur crank pulley bad for the h22a jdm motors what kind of long term and short term problems would arise with using these ur crank pulley?
The stock pulleys have three layers. metal, rubber, then metal. They act as an engine damper. It's alot like removing your balance shafts. Your pretty much shaving time off your engines life by reducing the stability of the whole thing. Especially if your revving it out all the time. It'll vibrate alot more up top.
i've had my UR pulley on for about a year now. engine has 184k miles now, 21k with the pulley. i'm awaiting its death, but it still seems to be pulling strong.
Having a balanced crankshaft and and pulley assambly works to correct first order vibrations caused by the imbalance of the rotating assembly (crank motion).
The balance shafts act upon the second order vibrations caused by the reciprocating assembly (up and down motion of pistons) which causes the engine to shake.
Here is a link to some info read the update at the very bottom of the page. Of course this is just one persons experiece mind you. http://www.ntpog.org/reviews/u...shtml
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluda92 »</TD></TR><TR><TD CLASS="quote">The stock pulleys have three layers. metal, rubber, then metal. They act as an engine damper. It's alot like removing your balance shafts. Your pretty much shaving time off your engines life by reducing the stability of the whole thing. Especially if your revving it out all the time. It'll vibrate alot more up top.</TD></TR></TABLE>
Wrong. The Prelude has *GASP* balance shafts. The engine is fine and WILL NOT LOSE LIFE because of the pully. You are referring to a different engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden »</TD></TR><TR><TD CLASS="quote">The stock crank pulley is also dampened.</TD></TR></TABLE>
......and honda made it dampened, for a reason
it's not worth the money or the few "extra hp" it makes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Si »</TD></TR><TR><TD CLASS="quote">
it's not worth the money or the few "extra hp" it makes</TD></TR></TABLE>
i'm enjoying mine.
i'm enjoying mine.
the damper is really not need, the old honda engines never had it and they ran for many 100,000 miles...the honda cranks are soo well balanced u can run the UR crank pulley's without a glich. A member of PO.com had a crank pulley and said it was a "UR Pulley" but it wasnt and it broke, yet UR has never had one broken crank pulley or no motor has crankwalked b/c of thier crankpulley so u are safe.
