Changed axles still vibrations!!
Old Dec 13, 2003 | 02:34 PM
DEVIN22CBR's Avatar
Default Changed axles still vibrations!!
So i was having some pretty hard vibrations when I accelerate, went to get my Autozne lifetime warrentie axles ..swapped em both out and it actually feels worse now Im thinking on my drivers side . I had them get me another one tomrrow but has anyone ever had a problem with these or any other thins causing vibrations ?
edit: Using 90-93 Integra axles in a B20z Crx Si
Old Dec 13, 2003 | 02:42 PM
RCautoworks's Avatar
Default Re: Changed axles still vibrations!! (Sac)
Is there any other problems besides the vibration ?
Old Dec 13, 2003 | 02:45 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Changed axles still vibrations!! (90blackcrx)
did u recently change the clutch?
DEVIN22CBR's Avatar
Default Re: Changed axles still vibrations!! (ind3ciso)
Clutch is new act etc etc ..I just changed the axle as we speak today ..It wasnt even this bad before, the vibration are worse now with this axle in.
EDIT: THEY ARE 93 axles I bleive for a 1.8 non vtec
Modified by Sac at 6:58 PM 12/13/2003
Old Dec 13, 2003 | 03:01 PM
Does it vibrate the hole car ? Why did you think it was the axles ? How are the engine mounts ?
Old Dec 13, 2003 | 03:03 PM
DEVIN22CBR's Avatar
Nver happend this bad entill I put these in though! It was just when i turned now its in a danm straight line. Mounts are fine . It vibrates my side pretty much. Feels like I have sqaure tires
Old Dec 13, 2003 | 03:07 PM
kylefakesi-r's Avatar
what mounts?
is one of the strut rods cracked or anything like that?
tire condition?
Old Dec 13, 2003 | 03:09 PM
DEVIN22CBR's Avatar
Default Re: Changed axles still vibrations!! (kylefakesi-r)
Struts are Kyb 4 ways new. Hasport Mounts. New tires also . Never was this bad till today . Im guessing Autozne axles are kinda like pickin n grab you have a 50/50 chance of getting a fubar axle ?
Old Dec 13, 2003 | 03:10 PM
HatchBox's Avatar
Skoobie no more...
if the nuts on the clutch presure plate arent to spec and arent tight enough or too tight the clutch wont be seated propery, and it will be fine for a litte bit, but then one day out the blue it will start to vibrate on acceleration,,,then soon vibrate all the damn time
Old Dec 13, 2003 | 03:17 PM
DEVIN22CBR's Avatar
The 12 point 10mm nuts ? I tq spec everything . They arent that much I know .
Old Dec 13, 2003 | 03:20 PM
esoterEK..'s Avatar
i have Protane mounts insert in my eg with b18c1 vibration is NORMAL for me
Old Dec 13, 2003 | 03:22 PM
DEVIN22CBR's Avatar
Default Re: Changed axles still vibrations!! (EGkwazhimoto)
Im use to vibrations (I own a crx ) but not vibrations when you acclerate. Thats not normal.
Old Dec 13, 2003 | 03:40 PM
the srut rod...not hte struts. the rod taht is attached to the lca and runs up to the front crossmember...is yours cracked or bent?
Old Dec 13, 2003 | 03:41 PM
DEVIN22CBR's Avatar
Sorry never heard that term . Yes its fine looked at em today actually as i was putting the axles in.
Old Dec 13, 2003 | 03:48 PM
Couple things to look into
Rotors
Dust rings ( you ever take these out during the swap )
Intermediate shaft
Old Dec 13, 2003 | 03:54 PM
DEVIN22CBR's Avatar
k I have brembo slotted rotors ...Dust rings are out ...90-93 Integra Intershaft.
Old Dec 13, 2003 | 04:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sac &raquo;</TD></TR><TR><TD CLASS="quote">k I have brembo slotted rotors ...Dust rings are out ...90-93 Integra Intershaft.</TD></TR></TABLE>
Are they old ? Any chance they could be warped maybe ?
Old Dec 13, 2003 | 04:23 PM
DEVIN22CBR's Avatar
Yeah they are fine.
Old Dec 13, 2003 | 05:45 PM
89b16hf's Avatar
i had the same problem my mid shaft was a little to long so i got the wrong on when i got my swap so i got the right one from a jdm obd0 b16a and it was all smooth after that
Old Dec 13, 2003 | 05:57 PM
Bunzino's Avatar
how about the wheel bearings?? might check that out
Old Dec 13, 2003 | 06:21 PM
Default Re: (Bunzino)
wheel bearings would make a grinding sound. the only way you would get vibration due to wheel bearings is if they completely seperated from the hub and teh only thing that was holding the wheel on was the rotor being pinched between the caliper. the detached hub would make a vibration...a bad bearing just makes noise.
Old Dec 13, 2003 | 06:25 PM
jaydmcrx's Avatar
My friend had the same problem, it was because they were crap autozone cheap axles. When he put junkyard oem honda axles back in it stopped.
Old Dec 13, 2003 | 08:42 PM
rasta420's Avatar
Default Re: (jaydmcrx)
yo check your lug nuts, my boy had the same problem. vibrated only while turning, then while goin straight or turning. turned out the front pass side lug nuts were loose.
wannaBjdmca6
Suspension & Brakes
Oct 16, 2010 05:25 PM
gettinmoneyny
Jul 2, 2010 08:30 PM
ILOVEYOURHONDA
Sep 25, 2009 08:50 PM
E-AT_me
Mar 10, 2008 09:51 AM
88 civic ef
Apr 19, 2006 03:01 PM
