B20 going into a CRX
Whats up, I'm going to put a B20 into a CRX and want to know if there is any additional stuff I need.
I have the motor, tranny, linkages, ls intake manifold, bseries exhaust manifold, axles and ecu..what mounts would I use? Could I just use some 94-97 integra mounts or do i need some hasport mounts? And should I get a new wiring harness??? Well any thoughts on this matter would be nice. Thanks
Hasport Mounts ...Linkage needs to be cut and rewelded or buy the linkage from place racing or somewhere ..Use a 90 91 Integra or 88 91 Si harness or Hf . 90 93- Ls ecu ls cable trans or any other b16 CABLE tranny you come upon. 90 -93 Integra axles ...any integra b18b/a exhaust manifold ..intake mani is fine ...should be it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">hubs/knuckles need to change unless you have an Si.</TD></TR></TABLE>
Or a DX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">90 93- Ls ecu </TD></TR></TABLE>
90-91, as 92-93 is OBD1
Or a DX.
That must suck .:\
