License Plate Lights out...checked fuses/bulbs WHAT NEXT?
Old Dec 13, 2003 | 01:23 PM
AgentJam's Avatar
Default License Plate Lights out...checked fuses/bulbs WHAT NEXT?
My uncles 96 accord's licnese plate lights are out even after a fuse check and a bulb swap. I own a CRX so i'm unfamiliar with reacurring accord problems. Has anyone ever had this happen and is there another place i need to check before retracing all wiring? Where do those lights wire up to in the dash?
Thanks,
Vince
Old Dec 14, 2003 | 06:02 PM
Nick H's Avatar
New User
Default Re: License Plate Lights out...checked fuses/bulbs WHAT NEXT? (AgentJam)
well the obvious place to start checking for shorts would be where the wires cross the trunk to the body since run-off would happen there...i haven't heard of this with accords though and doesn't seem to be a very persistent problem...sorry to hear this...it looks like wiring is the problem though..
Old Dec 15, 2003 | 07:07 AM
4DRPIMPIN's Avatar
Default Re: License Plate Lights out...checked fuses/bulbs WHAT NEXT? (Nick H)
Check the plug that goes from the trunk to the body of the car. make sure it is plugged in. It should be next to the drivers side tailight
Old Dec 15, 2003 | 08:09 AM
AgentJam's Avatar
Default Re: License Plate Lights out...checked fuses/bulbs WHAT NEXT? (4DRPIMPIN)
Thanks guys
CrxBeastwood
May 18, 2013 05:34 PM
90DB1TegSedan
May 20, 2012 08:33 PM
d16y8crx
Jun 14, 2009 06:58 PM
Blk_prl
Sep 2, 2003 11:34 AM
