reverse = loud long squeek?
when i reverse, at times i hear a loud long squeek, it happens when i'm doing it slowly and braking, and i don't know what it is. I'm thinking its the breaks, but i never had this problem before untill i just recently raised up my car back on stock springs. Anyone got any info? could the installed messed up somthing to casue this or is it just that i got bad break pads
Sounds like you might got a Rock or something stuck in bewteen your pads and Brake?
Look at your Rotors, any sign of Wear? Indents made from objects?
I had that problem myself. You should check the e-brake cable to see that its not pinched or something and its keepin the rear brakes partially still on. Other than that, idk, good luck cuz i know that noise is absolutely horrendous
this happened to me a while ago,... and like a week later, I knew it was time to change my front brakes,... because that warning metal piece was hitting the rotor, my rotors were warped by the way....
I just changed the front brake pads and rotors and every thing is good as new !
jenoizm
Aug 19, 2005 04:45 PM
