how to identify a h22a LSD tranny
Old Dec 12, 2003 | 09:50 PM
mr. Grind's Avatar
Default how to identify a h22a LSD tranny
I am planning on getting a lsd tranny for my accord h22a swap but i don't know how to identify that i am getting a LSD and not a regular tranny
Are ther any special code or serial number on a lsd tranny that i should know of???
Also what king of price is ok...I want to make sure i am not being screw over with price or wrong tranny
Thanks
Old Dec 12, 2003 | 10:37 PM
H22sol's Avatar
Default Re: how to identify a h22a LSD tranny (kingmarc01)
The way to identify an LSD tranny is to pop off the plug above the where the axle goes i think, my plug was red and i guess u can see the axle if u look through it. non LSD trannys have like a little bar going across in the hole. kinda hard to explain, sorry.
Old Dec 13, 2003 | 01:59 AM
dankbudz11357's Avatar
Default Re: how to identify a h22a LSD tranny (H22sol)
it's pretty easy actually, been explained many a times. pretty much the way you said, i think, pretty sure though. try a search
Old Dec 13, 2003 | 06:57 AM
jdm22vtec's Avatar
Default Re: how to identify a h22a LSD tranny (dankbudz11357)
wtf? why pop off the axle when you can just look on the tranny for the code. Its right where the tranny meets the block. There's a serial number or some **** and should say m2b4 if its lsd. m2a4 if its not.
Old Dec 13, 2003 | 08:59 AM
skunk2lude01's Avatar
some people scratch it off especially if they are trying to rip you. Chances are it will be somewhere with a lift, you can do the old spin the tires method or you can look for a pin(obstruction) inbetween the hole where the axles at.
si90rex
May 19, 2006 11:21 AM
2lude4u
Dec 4, 2004 08:20 PM
ricebox
Mar 29, 2004 08:56 AM
Mr.DC2TurBo
20
Jul 23, 2003 09:04 AM
Markaccord95
Nov 21, 2002 04:25 PM
