Parting out my turbo project 91 integra
Parting out my 91 integra OVER 25K INVESTED
P&P LS head 3 angle valve job 60 miles on rebuild-400
Gude cams 431 lift 236 duration-300
Crower double springs titanium retainers-225
Adj. Weapon R cam gears 4 bolt polished-85
arp Head studs 60 miles-75
Holley 68mm tb (green) for 2000 Integra but fits my 91-225
2 1/4 chrome drag IC piping greddy bov flange-250
Drag ported turbo manifold egt taped externaly gated-225
Delta Gate waste gate and dump tube 35mm-100 PENDING
Greddy type s BOV-125PENDING
Turbonetics ported T3/T4 57trim polished cold side (no play)-450
3" down pipe-125
3"test pipe and cat back stainles steel-250
Apexi 3" N1 muffler (magenta) -150
Walbro 255 lph high volume in tank fuel pump-75
Blue Moroso batery box sealed-75
Fluidyne Radiator-275
MSD 6BTM-260
MSD Blaster 2 coil-25
MSD 2 step-40
MSD OBD 1 distributor cap (NEW)-SOLD
FJO Wideband W/ datalogging, data cable included display is missing plastic cover I had it custom mounted less than 300 miles (1200 new) hooks up to laptop (optional)-650
Electronic EGT Meter back lit green 2 prob input comes with k type probe-200
GM 3 bar map (NEW)-SOLD
AEM EMS for OBD 1 cars (NEW NEVER USED) 1500 new-1000 PENDING
OBD 1 distributor (NEW rotor)-SOLD
OBD 0 to OBD 1 computer harness-125
4 wire O2 bosh (NEW)-45
Sheet metal ported intake manifold (looks like venom) polished and port matched to the ported LS head-250
blue top 440cc injectors-75
blue top 450cc injectors-75
Denso 550cc injectors W/ clips-150
Lokar adj. stainless steel throtle cable-40
Auto meter boost/vacume guage ultra silver-35
Auto meter air/fuel ratio ultra silver-45
Auto metet 5" monster tach with shift light ultra silver-175
Auto meter dual guage pod carbon fiber 25
Greddy black turbo timer-75-
turbo XS high performance manual boost controller(have original box)-100
Aem polished adj fuel pressure regulator ( I had to JB weld a new vacume port on it but it does NOT leak and you can hardly tell)-100
91 acura integra LS special moon roof power windows a/c cruise controll. black and tan interior.( I was going to dye it all black)
I am also selling the car Lambo orange paint garage kept painted last winter drove about 400 miles. It has around 130k on it but almost everything is new on it.
Newer motor from a 92 with 65k in it
newer tranny with 60K on it
Action 6 puck sprung clutch/plate
lifetime axles
lifetime distributor
new honda timing belt
prothane motor mount inserts
Kennwood excelond cd player
Kennwood 6 disk changer mounted in the glove box
Orion tri mode amp ( hook up you interior speakers and subs on one amp)
4guage wire kit
polk 5 1/4 components in ft
Pioneer 6 1/2 in rear
ft strut bar
rear strut bar
Neuspeed short shifter
neuspeed wires
newformz block guard
neuspeed race springs 1.7 drop
ingles adj. caster kit on the ft
eibach kit on rear
17" S10 rims
dunlop tires 75% tread
K&N air filter
akimoto intake
adj indeglow guages
2 brand new ft fenders ( there molded into the side skirts so I got new ones)
Brand new hood
auto meter fuel pressure guage
body kit- BW front and Andy's sides and rear custom molded corvette hood on the car all the side moldings are filled in. I paid 4000.00 for the body work on this car. IT IS FLAWLESS.......................................... ...........
This car does not have an exhaust but I do have the stock header. I have a 3" I can work a deal on if you want.
A/c is removed but have everything
I am sure there is alot more I am forgetting. For pics check out my image station. 8000 for the car or BO. 14,000 for EVERYTHING (save over 1000 bucks)
I am truly crying, I really dont want to get rid of this but I need a house more than a car.
Modified by nitroice40 at 10:37 PM 12/12/2003
Modified by nitroice40 at 10:44 PM 12/12/2003
Modified by nitroice40 at 11:06 PM 12/12/2003
Modified by nitroice40 at 10:46 AM 12/13/2003
Modified by nitroice40 at 12:24 PM 12/13/2003
Modified by nitroice40 at 12:29 PM 12/13/2003
Modified by nitroice40 at 7:30 PM 12/13/2003
Modified by nitroice40 at 9:34 PM 12/13/2003
Modified by nitroice40 at 11:40 PM 12/13/2003
Modified by nitroice40 at 9:06 PM 12/14/2003
3" down pipe-125
MSD 6BTM-260
MSD 2 step-40
lifetime axles
4guage wire kit
ft strut bar
rear strut bar
neuspeed wires
eibach kit on rear
17" S10 rims
K&N air filter
akimoto intake
adj indeglow guages
Brand new hood
nitroice40
Dec 21, 2003 06:49 AM
