5th gen Shock Knock - How do you fix it?
Old Dec 12, 2003 | 08:10 AM
fubar's Avatar
Default 5th gen Shock Knock - How do you fix it?
I have a 1999 Prelude and have the annoying "shock knock" (coming from the rear passenger area). I've done a search on the web for a fix, which always led to the same source for the solution to this problem, however the link is now dead. So I was wondering if someone here knows how to fix it and can describe the process.
Thanks in advance
Old Dec 12, 2003 | 01:36 PM
97lude's Avatar
Default Re: 5th gen Shock Knock - How do you fix it? (fubar)
i'm having the same problem
Old Dec 12, 2003 | 02:40 PM
al_r's Avatar
Default Re: 5th gen Shock Knock - How do you fix it? (97Lude)
If it's really shock knock, Honda's fix is to replace the spacers under the strut hat with ones that are 2mm shorter. Original are 39mm, replacements are 37mm. Should be easy to trim the originals to that length, but still requires you pulling the strut(s) and taking them apart to get at the spacer.
btr24evr
Feb 1, 2003 09:05 AM
rybred
Dec 5, 2002 10:25 AM
AmeenR
Jul 13, 2002 12:39 PM
