injector - LS/GSR & OBDI/OBDII
Old Sep 20, 2001 | 07:16 AM
Hunter_EL's Avatar
New User
Default injector - LS/GSR & OBDI/OBDII
Hello All,
In looking through the archives I've found confirmation that OBDI and OBDII injectors are compatible, on a seperate thread I found that OBDI LS injectors are interchangeable with OBDII GSR Injectors (both are 240cc)
SO.. can someone please confirm that OBDII LS injectors are identical to OBDI GSR injectors.
I am running an 95 GSR (OBDI) engine in an EK civic (OBDII). OBDII harness, Distributor, Alternator and using OBDII LS injectors to bypass splicing the OBDI injector connector plugs.
thanks all.
Old Sep 20, 2001 | 08:08 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: injector - LS/GSR & OBDI/OBDII (T_Sem)
No, they are not. The OBD2 injector has a bit of a different plug on it than the OBD1.
This is why, when you purchase injectors from RC, you have to buy the adapter harness for the OBD1 style injectors and wire them into your OBD2 car.
Old Sep 20, 2001 | 10:04 AM
Hunter_EL's Avatar
New User
Default Re: injector - LS/GSR & OBDI/OBDII (B18C-EJ1)
uhm.. to clarify. I know that they have a different plug, this is actually why I'm asking the question..
If both the OBDI GSR and OBDII LS injectors are the same: i.e. both 240CC peak and hold or saturated (which one?) and looking for the same impedance etc..
As long as they are the SAME in terms of performance specs above, I'm not concerned with whether the plugs/connectors are the same.
Old Sep 20, 2001 | 10:10 AM
WAFFLES's Avatar
yeah the plugs are all the same in terms of cc
Old Sep 20, 2001 | 11:02 PM
SpeedCon Turbo ZC 619's Avatar
New User
yes they are compatible. yes they are the same in flow ratings 240 cc's. the only difference is the plug/connector. think about this when people with 96 and up cars use the obd 1 to obd 2 convertor harness so they can run an obd 1 ecu do you ever see them switching to obd 1 injectors? hope that cleared things up for you.
Old Sep 21, 2001 | 02:25 AM
B18C-EJ1
Guest
Posts: n/a
They are saturated. Yes, the both flow the same, but you need the adapter to put OBD1 into an OBD2 car. I guess I didn't clairfy myself.
Old Sep 21, 2001 | 09:22 AM
Hunter_EL's Avatar
New User
Excellent. Sorry for the confusion, and thanks again for the help guys,
/T
puppet_828
12
Dec 6, 2012 02:30 PM
jyracer
Nov 23, 2009 05:56 AM
snowpro127
Nov 18, 2009 06:57 AM
bettsbanger
Feb 4, 2009 11:12 AM
ISawUL00k
Dec 2, 2008 12:14 AM
