b16a2, stock block, 8psi..... what turbo?
Old Dec 12, 2003 | 12:27 AM
Charbon Sty's Avatar
Default b16a2, stock block, 8psi..... what turbo?
hey people, as the topic reads, im aiming to keep the block stock, i wanna run 8psi its pretty much a daily driver, but i could just use it 2 days a week or so.
i wanna know what turbo to use for the most power out of this block (ive read that about 210kw is the limits to the standard block), i wouldnt mind if the turbo didnt spool till 4000rpm+
what specs on the turbo should i be looking for?
i was thinking a t3/to4e... but not sure what specs i should be lookin for...
cheers in advance
Old Dec 12, 2003 | 01:06 AM
r7's Avatar
r7
Default Re: b16a2, stock block, 8psi..... what turbo? (kelsonmassif)
t3/t04e here, .48 , .60 compressor.. making 252whp on a dynojet @ 7psi.. stock b16a1
Old Dec 12, 2003 | 07:29 AM
TurboJesse
Guest
Posts: n/a
Default Re: b16a2, stock block, 8psi..... what turbo? (r7)
don't limit your car to the boost you wanna run , that is almost meaningless, limit it to the power you wanna make.
Old Dec 12, 2003 | 12:33 PM
Default Re: b16a2, stock block, 8psi..... what turbo? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">don't limit your car to the boost you wanna run , that is almost meaningless, limit it to the power you wanna make.</TD></TR></TABLE>
yea i want to make about 350whp eventually, if that helps in anyway
ive got so far a 255lph fuel pump, 510cc injectors, and a blow off valve. ill be keeping the turbo and computer (hondata s200) the last on the shopping list.
unrivaledintegra
Jan 21, 2008 03:08 PM
DVPTeG
May 22, 2007 08:34 PM
meagainsttheworld
May 20, 2007 06:40 PM
JonnyCoupe
Mar 22, 2005 01:05 AM
