rear discs and exhaust
Old Dec 11, 2003 | 05:14 PM
cpizzy's Avatar
Default rear discs and exhaust
I might be getting an 88 crx dx with jdm zc dohc motor for a good price
I am wondering if the rear suspenion (trailing arms i think there called and rear disc setup will work on the crx and if so what modifications are needed.
Also what is a good exhaust system for the crx
anything else I should know would be great to
Old Dec 11, 2003 | 05:17 PM
bryant's Avatar
Default Re: rear discs and exhaust (cexodusk)
CRX 90-91 Si rear disk with the e-brake cables work fine. also 92-01 integra rear disk with the e-brake cable will also work.
Exhaust, Please do a search you will find tons of stuff for it.
Old Dec 11, 2003 | 05:20 PM
kylefakesi-r's Avatar
90-93 integra and 91 crx si are bolton for the rear disc trailing arms
greddy, hks, thermal r&d, custom
i own the greddy on my hatch and i love it but i really wish i had bought the hks for it's much more stock appearance. the thermal is ok and all stainless but i really don't like how it appears from the rear of the car-the tip looks goofy and the muffler appears to be the wrong size.
for a custom setup i would recomend the es oval from jdmhondaparts and a muffler shop resonator shortly after the cat...use the same size piping as the muffler inlet/outlet and rout it in the stock positions. this system looks pretty good and is more than affordable.
Old Dec 11, 2003 | 05:24 PM
cpizzy's Avatar
alright thanks guys
Old Dec 11, 2003 | 07:03 PM
ThatRicerDaniel's Avatar
Default Re: (cexodusk)
greddy trust baby.
nice and clean. not to loud either. i have a 2 inch tip on mine.
Old Dec 11, 2003 | 07:45 PM
speed_racer012's Avatar
Default Re: (NitrousDreamz)
how is the skunk 2 system? I'm either going skunk 2 or greddy
Old Dec 11, 2003 | 07:49 PM
wu tang's Avatar
Default Re: (speed_racer012)
i have thermal, and its the best i think, cause when your cruzin on the freeway, its not loud, but when you get on it, it sounds mean, and then when vtec hits, its just a good ole sound.
Old Dec 11, 2003 | 09:16 PM
88civicHB703's Avatar
90-93 integra's rear disk system for 88-91 civic hatchback, crx si 88-91 ebrake cable to complete this swap. rsr also make exhaust for 88-91 EF's.. check on http://www.turboimport.com
Old Dec 11, 2003 | 10:42 PM
Vinceg99's Avatar
Default Re: (88civicHB703)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88civicHB703 &raquo;</TD></TR><TR><TD CLASS="quote">90-93 integra's rear disk system for 88-91 civic hatchback, crx si 88-91 ebrake cable to complete this swap. rsr also make exhaust for 88-91 EF's.. check on http://www.turboimport.com</TD></TR></TABLE>
You cant use the 88 or 89 CRX si ebrake cable since they have rear drum. Also you cant use ANY of the CRX ebrake cables on a Hatch since they will be too short.
Old Dec 11, 2003 | 10:50 PM
http://www.fourthgenhatch.com/reardiscswap.html
egchan
Jul 7, 2004 03:50 AM
onesikcivic
Dec 19, 2003 09:28 AM
busychild
Sep 16, 2003 06:00 AM
cd1fidy
Apr 10, 2003 12:34 PM
