90,000 major maintenance
Old Dec 11, 2003 | 05:01 PM
arren123's Avatar
Default 90,000 major maintenance
I'm coming up to 90,000 miles soon and I'm going to order the parts I need.
What items should I get OEM, and what can I safely go with an aftermarket brand?
Here's the list:
1) Timing Belt *
2) Water Pump
3) Timing Belt Tensioner
4) Timing Belt Tensioner Spring *
5) Distributor Cap
6) Distributor Rotor
7) Valve Cover Gasket
8) Valve Cover Washer Seals
9) Spark Splug Seals
10) PCV Valve
11) Fuel Filter *
12) Spark Plugs *
The * Items I'm thinking of going OEM and the rest aftermarket to save money.
What do you think?
I'm kind of torn with the water pump. The price difference between OEM and aftermarket (NPW http://img.eautopartscatalog.c...W.JPG , or ATS brand http://img.eautopartscatalog.c...S.JPG ) is $60.
Old Dec 11, 2003 | 05:03 PM
RockstarJR's Avatar
Default Re: 90,000 major maintenance (arren123)
oem
Old Dec 11, 2003 | 05:13 PM
esponet's Avatar
everything should be oem but this is the most important.
1) Timing Belt *
2) Water Pump
5) Distributor Cap
Old Dec 11, 2003 | 05:18 PM
B2FiNiTY's Avatar
Get all OEM
Old Dec 11, 2003 | 05:47 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arren123 &raquo;</TD></TR><TR><TD CLASS="quote">I'm coming up to 90,000 miles soon and I'm going to order the parts I need.
Here's the list:
1) Timing Belt *
2) Water Pump
5) Distributor Cap
10) PCV Valve
11) Fuel Filter *
12) Spark Plugs *
What do you think?
o.k. now.. maybe i missed someting somewhre.. but whats timing belt tensioner spring? isn't that inside the timing belt tensioner?
btw.. https://honda-tech.com/zerothread?id=644633 - they supposed to be oem but for much better price.
Old Dec 11, 2003 | 06:04 PM
Kendall's Avatar
I agree, OEM unless you plan on producing some sick power with it, then maybe a Toda timing belt.
Old Dec 11, 2003 | 06:27 PM
arren123's Avatar
Default Re: 90,000 major maintenance (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
Nope.. The tensioner spring connects to the tensioner. If you look at the picture, the bolt goes through the middle of the tensioner and the spring connections to the eyelet. I know on my civic, theres only one eyelet. I have to check the helms to see why this one shows two eyelets.
The spring is only a few bucks, so I might as well replace that too while I'm at it.
So I guess so far the consensus is, I should skimp on the water pump eh?
Any of you running a non-OEM water pump?
Old Dec 11, 2003 | 06:53 PM
vtec.dc2's Avatar
i see.. i missed that.. maybe next time.. as far as non-oem, i don't think its worth the risk, the only place i'd consider is the link i mentiooned from above...
Old Dec 11, 2003 | 06:57 PM
mickey513's Avatar
http://www.ahmotor.com
All OEM honda & Acura parts.
About 25% cheaper then your local Honda or Acura dealer parts dept. If I were you, I would order the parts from the site. Shipping is really reasonable too.
Old Dec 11, 2003 | 09:46 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arren123 &raquo;</TD></TR><TR><TD CLASS="quote">If you look at the picture, the bolt goes through the middle of the tensioner and the spring connections to the eyelet. I know on my civic, theres only one eyelet. I have to check the helms to see why this one shows two eyelets. </TD></TR></TABLE>
One eyelet fits over a pivot pin. The other one is for the tensioner spring.
daochihung
Jun 1, 2011 07:41 PM
TeaAddict
Nov 27, 2006 10:12 AM
GSR_96814
Apr 20, 2006 08:17 AM
schumi
Jun 10, 2005 08:56 AM
1ntensiveVTECivic
Dec 19, 2003 10:29 PM
