92-96 Prelude Strut Bar *Searched*
Old Dec 11, 2003 | 02:48 PM
xxxxxxxxxxxx's Avatar
Default 92-96 Prelude Strut Bar *Searched*
I was wondering, anyone know what a good strut bar for a 4th gen prelude would be?
-Thanks
Old Dec 11, 2003 | 03:04 PM
jdm22vtec's Avatar
Default Re: 92-96 Prelude Strut Bar *Searched* (bjorgen)
a metal one. thats what i use....
if you're not autoxing or anything like that than i would reccomend the $15 ones from ebay. There's really not a point to spend $200 for a spoon or dc sports unless you're more worried about what it looks like.
just my .02
Old Dec 11, 2003 | 03:25 PM
spnbb2
Guest
Posts: n/a
sp0000000000000000000000000000n
Old Dec 11, 2003 | 03:31 PM
JG Luder's Avatar
Default Re: 92-96 Prelude Strut Bar *Searched* (jdm22vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm22vtec &raquo;</TD></TR><TR><TD CLASS="quote">a metal one. thats what i use....
just my .02
you aren't the only one that feels that way.
what he said x2 for me.
Old Dec 11, 2003 | 03:33 PM
Behan's Avatar
Default Re: 92-96 Prelude Strut Bar *Searched* (Lone Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lone Luder &raquo;</TD></TR><TR><TD CLASS="quote">
+1, if looks aren't a concern go with cheap ones.
Old Dec 11, 2003 | 03:36 PM
Thanks for the help
Old Dec 11, 2003 | 04:30 PM
satan_srv's Avatar
Default Re: (bjorgen)
I use a spoon, if you can get one I highly recommend
Old Dec 11, 2003 | 04:35 PM
4bidden's Avatar
Spoooon!!!! OR Neuspeed
Here is my xmas gift....
Old Dec 11, 2003 | 05:26 PM
JG Luder's Avatar
Default Re: (4bidden)
SPORK!!!!!!!!!!!
Old Dec 11, 2003 | 05:36 PM
SKDRCR's Avatar
Default Re: (Lone Luder)
neuspeed is probably the best bang for your buck
Old Dec 11, 2003 | 06:20 PM
LudeyKrus's Avatar
Default Re: (SKDRCR)
Make your own
Old Dec 11, 2003 | 06:42 PM
kg-mm.bb2's Avatar
I got the Spoon front and rear strut bars about a year ago. Made a big
difference in handling especially when you push the car to its limits. I got
both on ebay from one guy, used but worth it.
Old Dec 11, 2003 | 07:45 PM
JDMAflac's Avatar
I was trying to install a strut bar today but i found out that one of my strut tower bolts is rounded off....how can i get it off? I dont think a nut splitter will do the trick since it wont fit there in the first place. Grind it off?
Old Dec 11, 2003 | 09:18 PM
@ries's Avatar
Default Re: (AznLuder704)
Old Dec 11, 2003 | 10:51 PM
94vtirozguy's Avatar
neuspeed front, i didnt worry about the rear one, the prelude chassis at the rear has no reall weight and the chassis is pretty strong, so no reason to install the rear.
Old Dec 11, 2003 | 11:42 PM
VTECRaZeR's Avatar
I would say Spoon or Neuspeed for what I heard.
I got a tenzo r my self....haven't installed it yet though so I couldn't tell you.
Old Dec 12, 2003 | 04:22 AM
Jagan'92's Avatar
ebay special 15$ for both front and rear.
200$ is half a mortgage payment for me.
Old Dec 12, 2003 | 06:35 AM
BA5's Avatar
BA5
Default Re: 92-96 Prelude Strut Bar *Searched* (Jagan'92)
How about a cusco one?
I have cusco bar for my 3g. Very well made, *very* stiff, rather heavy. It's also welded on the ends, instead of the pivot ends.
Old Dec 13, 2003 | 07:32 AM
Xlerate9's Avatar
Default Re: (94vtirozguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtirozguy &raquo;</TD></TR><TR><TD CLASS="quote">neuspeed front, i didnt worry about the rear one, the prelude chassis at the rear has no reall weight and the chassis is pretty strong, so no reason to install the rear.</TD></TR></TABLE>
The rear bar made a HUGE difference. It's def worth it. I think it makes a bigger difference than the front. Don't get it confused with the rear lower tie bar... it doesn't do much for the reasons you've stated...
I went with neuspeed front and spoon rear.
Old Dec 13, 2003 | 08:04 AM
92LudeSI's Avatar
I have an ebay special and it works just fine i wouldnt spend any money on a namebrand one.
Old Dec 13, 2003 | 01:40 PM
Que_Lude's Avatar
Default Re: (satan_srv)
Hey Joel, I see that you don't have the rubber hood gasket connected in the photo. Did you remove it to get more air to flow though your engine bay?
Old Feb 21, 2004 | 08:48 AM
blklude's Avatar
Does 5th gen strut bars fit 4th gens (Vtec)?
Old Feb 21, 2004 | 10:20 AM
satan_srv's Avatar
Default Re: (Que_Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Que_Lude &raquo;</TD></TR><TR><TD CLASS="quote">Hey Joel, I see that you don't have the rubber hood gasket connected in the photo. Did you remove it to get more air to flow though your engine bay?</TD></TR></TABLE>
what? on the edge of the firewall? I must have just lost it at some point. I should get one though!
satan_srv's Avatar
Default Re: 92-96 Prelude Strut Bar *Searched* (blklude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blklude &raquo;</TD></TR><TR><TD CLASS="quote">Does 5th gen strut bars fit 4th gens (Vtec)?</TD></TR></TABLE>
Front no. Rear Yes.
Old Feb 21, 2004 | 11:07 AM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznLuder704 &raquo;</TD></TR><TR><TD CLASS="quote">I was trying to install a strut bar today but i found out that one of my strut tower bolts is rounded off....how can i get it off? I dont think a nut splitter will do the trick since it wont fit there in the first place. Grind it off?</TD></TR></TABLE>
Vise-grips should work ..... not sure if it would fit though
