Ek CTR CLUSTER HELP
Old Dec 11, 2003 | 02:20 PM
Beatkidd's Avatar
Default Ek CTR CLUSTER HELP
if you turn the cluster over there are 4
plugs the two top that the blue plugs go into
and a small orange and yellow at the bottom.
i only have three plugs though the 2 top blue and the yellow
i am missing the orange. Does anyone know what the orange plug is used for?
thanks
Old Dec 11, 2003 | 02:22 PM
blackhatchy's Avatar
Default Re: Ek CTR CLUSTER HELP (Beatkidd)
if you follow the connectors to what light they go to, it should be easy to figure out
Old Dec 11, 2003 | 02:24 PM
Beatkidd's Avatar
Default Re: Ek CTR CLUSTER HELP (blackhatchy)
i recived a seperate harness and i only the 2 large clue connectors and asmall yellow one no orange
Old Dec 11, 2003 | 02:31 PM
ITRacer121's Avatar
I know one is for SRS but have no idea what color it is but it plugs in behind the tach
Old Dec 11, 2003 | 03:10 PM
Built Beast's Avatar
Default Re: (ITRacer121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRacer121 &raquo;</TD></TR><TR><TD CLASS="quote">I know one is for SRS but have no idea what color it is but it plugs in behind the tach</TD></TR></TABLE>
I believe that it is the yellow one
Old Dec 11, 2003 | 03:12 PM
Beatkidd's Avatar
Default Re: (R33CIVIC)
so does anyone know what the orange is for?
anyone have a helms manual?
Old Dec 11, 2003 | 03:42 PM
Ricey McRicerton's Avatar
Default Re: (Beatkidd)
Did the CTR come with crusie control?? If so that's what it is.
Old Dec 11, 2003 | 03:44 PM
Beatkidd's Avatar
Default Re: (Ricey McRicerton)
Did some research with the helms manual
and urenamehere thinks its for the ABS light
that sounds about right
Old Dec 11, 2003 | 05:16 PM
kingSfit's Avatar
yes!
710dabber
Jun 15, 2015 03:14 PM
JEFFOS69
Honda S2000
Nov 12, 2006 06:18 AM
Kevin Type Si
May 12, 2004 05:08 AM
DriveSideWays
Feb 2, 2004 04:57 AM
IdotheSHOCKER
Mar 15, 2003 01:19 PM
