Mixing brake fluid
Old Sep 19, 2001 | 07:31 PM
Integ Grl's Avatar
Default Mixing brake fluid
I went to the Acura dealer for service a couple weeks ago. I didn't notice until I got home and looked under the hood, but I guess as a favor for having me wait so long, they topped off the fluids in my car, including the brake fluid. I am currently using ATE Super Blue. Will the mixing of the Honda and ATE fluid affect braking in any way? Should I just get the whole system flushed out?
TIA!
Old Sep 19, 2001 | 11:31 PM
Lei Siew Long's Avatar
Default Re: Mixing brake fluid (Integ_GrL)
for the most part it isn't recommended to mix the brake fluid because the fluids might not work well together. because i think (don't quote me on this) the brakes will not work to its full potential with certain mixtures.
Old Sep 19, 2001 | 11:33 PM
nfn15037's Avatar
Default Re: Mixing brake fluid (boostedeg6)
Same thing happened to me! I had just put new Motul fluid in a few weeks earlier, the level was fine, but they just HAD to add a little, i was so pissed cuz that Motul stuff is so expensive, just tell em before u have anything done next time
Old Sep 20, 2001 | 06:51 AM
MaddMatt's Avatar
Default Re: Mixing brake fluid (nfn15037)
The big thing is don't mix the DOT 5.0 silicon based fluid with anything like 3.0, 4.0, or 5.1 DOT fluid. As long as you don't do that, you should be fine. Although it would **** me off too if that happend to me....
DC4R27
Dec 2, 2009 10:03 AM
2k1 SSM GSR
Mar 23, 2005 10:02 AM
SilverDc2
Jun 6, 2004 08:54 PM
JSIR
Apr 27, 2002 10:27 PM
Flux
Oct 6, 2001 12:07 PM
