How hard is it to change a timing belt of an Accord 2.3L 1999?
Old Dec 11, 2003 | 09:34 AM
Saintor's Avatar
Default How hard is it to change a timing belt of an Accord 2.3L 1999?
I did a tb change on a Mazda a few years ago and it was relatively easy.
The dealer wants 400$CAD for this. My car has 70000+ miles and they say that
it should have been done at 60000 miles, although the owner's manual says
105000 miles for rgular conditions. Is there a procedure detailed online
somewhere? Any case of broken timing belt FOR THIS SPECIFIC engine? TIA.
Old Dec 11, 2003 | 09:40 AM
knowtomorrow3001's Avatar
Default Re: How hard is it to change a timing belt of an Accord 2.3L 1999? (Saintor)
If it breaks it will preety much ruin your engine if yours is interference engine like mine
Modified by knowtomorrow3001 at 6:51 PM 12/11/2003
Old Dec 11, 2003 | 10:04 AM
The_Todd's Avatar
Farts in the shower
Default Re: How hard is it to change a timing belt of an Accord 2.3L 1999? (knowtomorrow3001)
what is an interference engine? is that the new rotary honda engine? cheers
Old Dec 11, 2003 | 12:46 PM
Starrman85's Avatar
Default Re: How hard is it to change a timing belt of an Accord 2.3L 1999? (VRDrvr)
an interference engine, if i recall correctly is where there isn't too much clearence between the cam cover and the cam shafts and valves and all that stuff. so if the timing belt breaks, all that stuff is going to slam into the cam cover, because there isn't a lot of clearence.
anyone correct me if i'm wrong.
Old Dec 11, 2003 | 01:12 PM
The_Todd's Avatar
Farts in the shower
Default Re: How hard is it to change a timing belt of an Accord 2.3L 1999? (STARRMAN85)
Then I stand corrected....never even heard of it, at least not as a type of engine....guess I do learn something new everyday.
Old Dec 11, 2003 | 01:17 PM
JimBlake's Avatar
Well, not quite. An interference engine means the valves open far enough that they'd hit the piston IF the piston were at TDC. Most Hondas are interference.
So when the timing belt breaks, the piston can come up & hit an open valve. That's not usually a good thing.
Old Dec 11, 2003 | 08:09 PM
Starrman85's Avatar
Default Re: How hard is it to change a timing belt of an Accord 2.3L 1999? (JimBlake)
thanks for the info...i knew it had something to do with pistons and valves hitting something...i guess hitting each other
Old Dec 12, 2003 | 05:55 AM
Saintor's Avatar
So there is no Honda mechanic here.
Old Dec 12, 2003 | 06:02 AM
jweller's Avatar
Changing the timing belt is pretty easy. no worse than any other motor i guess. If you've done other cars you should be able to handle this one. just get the helms manual and it will walk you right through it
getting the crank pulley bolt off is a complete bitch though. even air tools are no gaurantee of success. thats really the only difficult part.
if the belt breaks, you will most likely bend a valve.
heres an online how2 for the f22. the f23 is essentially the same thing but you don't need to do the balance shaft oil seal thing.
http://www.cybertrails.com/~pu....html
msrief
Mar 17, 2018 08:50 PM
dce
Aug 24, 2007 07:20 AM
lysol
Apr 14, 2004 09:12 AM
Bubble Gum Jr.
Jan 2, 2003 12:20 PM
