bigger throttle body? crv throttle body will fit?
ok, so with spec b's (possibly spec c's):
Would it make sense to go with a bigger throttle body?
I've heard that the crv throttle body can be straight-through bored for up to 64mm safely. Any advantages for someone like me?
Will a crv throttle body even work? What will it take to fit?
tia
Guest
Posts: n/a
The CRV is no different from the LS or GSR, just has a different linkage.
And yes, a overbored t-body will definatley help, IF you have the intake manifold port matched to the t-body.
